- Aug 22, 2012
- 4,111
Bad grammer, I actually meant just insulate the housing.
I will block all the side holes and gaps in the housing so no hot air will suck or blow.
Looking at some oven parts diagrams they appear to be for blowing air over the outside of the oven towards the door, possibly to actually cool the door???
So maybe it wont stand up to the heat. The major problem as I see it is the silicone bearing plate will deform or the motor windings will get too hot.
If that happens its relatively easy to make a new end plate for the rotor and extend the motor shaft getting it well away from the heat but I dont want to do that unless its necessary.
The blower has a weird silicone type bearing opposite the motor so I have a doubt it is although the fan rotor is metal bladed.I am thinking that unless the motor is rated for that kind of heat, I'd leave it exposed.
