powder coating oven
ch2co
Grumpy Old Man
H-M Supporter-Premium Member
Jan 9, 2013
752
Likes
461
#31
What? Not using carbon fiber tubing for your trusses? Shame shame, that thing is going to weigh a ton.
Unfortunately I have a great powder coater just 4 blocks (easy walking distance) from my house and they work with me so well.
My Surrier Truss plans for my little 10" are probably going to be alum tube, but carbon fiber is sooo tempting.
savarin
Aug 22, 2012
1,562
Likes
1,973
#34
I've worked with carbon fibre before and didnt like it much (building windsurfers) but it sure looks cool.
I dont mind heavy as it dont vibrate in the wind but then inertia starts rearing its ugly head.
savarin
Aug 22, 2012
1,562
Likes
1,973
#35
Found a fan at last, I hope its strong enough to take the heat, its from an electric oven and used to circulate air to cool the outside of the oven. It obviously gets hot in use but can it stand the temps I want.
I guess I will find out.
Made the holder to fit it to the oven wall
In place and a quick test shows it produces plenty of puff.
Now on to the ducting but I have a full calendar this week so not much more will get done.
savarin
Aug 22, 2012
1,562
Likes
1,973
#36
Got the ducting done
Now working on the outer insulated cover
The top section needs a box for the wiring and also be easily removable in case I have to replace the motor.
I'm still in two minds as to whether I should insulate the motor of leave it exposed.
It would be the only place where heat could leak away but its not a large area. Hmmmmm.
mark_f
Global Moderator
Staff member
May 2, 2014
1,987
Likes
2,269
#38
Randy is correct. Tbe motor needs to be exposed as the heat will ruin it. You could insulate the squirrel cage fan housing and leave the motor exposed as it is on the end of the fan housing. ( That's the way it looks in the photos ).
FOMOGO
Sep 2, 2013
1,451
Likes
1,174
#39
Coming along great. Oil-lite bushings, or bearings on the fan? If oil might want to make up some oiler tubes and give a drop or two every once and a while to help it live. Not too much too often, or it may cause issues with your finish. Cheers, Mike
savarin
Aug 22, 2012
1,562
Likes
1,973
#41
Bad grammer, I actually meant just insulate the housing.
I will block all the side holes and gaps in the housing so no hot air will suck or blow.
I am thinking that unless the motor is rated for that kind of heat, I'd leave it exposed.
The blower has a weird silicone type bearing opposite the motor so I have a doubt it is although the fan rotor is metal bladed.
Looking at some oven parts diagrams they appear to be for blowing air over the outside of the oven towards the door, possibly to actually cool the door???
So maybe it wont stand up to the heat. The major problem as I see it is the silicone bearing plate will deform or the motor windings will get too hot.
If that happens its relatively easy to make a new end plate for the rotor and extend the motor shaft getting it well away from the heat but I dont want to do that unless its necessary.
savarin
Aug 22, 2012
1,562
Likes
1,973
#42
Finished the rear of the oven
Now started on the door.
I stripped the glass out of the old oven and cleaned it but in the end I decided to rebuild the original door and set in in to my door.
All so I can watch paint dry.
savarin
Aug 22, 2012
1,562
Likes
1,973
#43
Got both sides of the door sheeted and in the process it twisted.
Closed at the top but wide open by 5" at the bottom so I placed a wedge at the top and clamped the bottom to twist it the other way
It worked spot on
Finishing off the wiring and door lock. Cant wait to fire her up.
savarin
Aug 22, 2012
1,562
Likes
1,973
#44
Finished. (Well almost)
The door shuts and holds tight,
The door gasket has to harden fully then I can trim the excess off, I used a high temp silicone as the gasket and greased the door frame so I could clamp them lightly together without them sticking.
All the wiring is done and it works.
Each item has its own warning light.
A splash of bolognaise and it almost looks edible!
The thermostat actually turns off the power at its lowest setting, turn it up and the power light comes on, flick the switch for the second element and that light comes on, turn the fan on and that light comes on.
The thermostat controls both heating elements so both lights turn off when the thermostat trips.
Both heating elements get hot.
I have to install the thermometer so I can read it outside the oven.
First job is to calibrate the thermostat, then I can fully cure the exhaust white paint inside and then its flat out powder coating the bits for the telescope to finish that.
Only another 6973 projects in the pipeline:bang head:
savarin
Aug 22, 2012
1,562
Likes
1,973
#45
first test is a possible let down.
According to the new oven thermometer it only gets to 185'C, I need 200.
But, when I opened the door and tested a metal bracket inside it read 204'C with my infra red thermometer which I would believe more than the cheap dial one.
However, the door warps at temp so heat leaks out there and the fan also pumps a bit of heat out its sides.
So, still work to do.
Think I should also add another element.
mark_f
Global Moderator
Staff member
May 2, 2014
1,987
Likes
2,269
#46
With a door that long, you need a latch near the top and another near the bottom. ( Connect them with a common rod so they work together).
savarin
Aug 22, 2012
1,562
Likes
1,973
#47
And a more pronounced gasket.
I will re make the door latch with 4 in total hooks to close it all the way down and add another hinge in the middle.
Cant do anything for the next two days, hosp appointments.
savarin
Aug 22, 2012
1,562
Likes
1,973
#50
The oven is finished and works. No more leaks and gets up to temperature.
Built a spray booth from wood and plastic sheeting.
and test sprayed a can
That looks a nice shiny black to me.
Now to strip the spray paint off the scope pier and sand blast a few parts and get them coated.
savarin
Aug 22, 2012
1,562
Likes
1,973
#51
No photos for the next bit but I decided to make a dedicated earth post.
I silver soldered two x 1meter lengths of hard drawn copper tube to make a 2 meter length, connected it to the hose pipe, turned it up full and started pushing it into the crap stuff we call soil here.
The top 500mm is dry sand/soil/gravel, next came a 800mm layer of dry clay finishing in fine sand.
Total time was approx 20 mins. Going through the clay was hard and was a sort of punch out a plug, lift to clear and re do.
I have never done this before and was totally surprised at how easy it was.
sanddan
Jan 22, 2012
637
Likes
620
#52
I had to pound in ground rods for my shop back in the day. Code at the time required them to be 6' down and at least 3' apart. We have clay soil so it was a bear to get that deep.
ch2co
Grumpy Old Man
Jan 9, 2013
752
Likes
461
#53
I'm impressed! What a project.
I don't remember, do you use electrostatic attraction in your spray booth? If so what do you use to power it, two balloons rubbed together or maybe a neon sign transformer? ;-}
savarin
Aug 22, 2012
1,562
Likes
1,973
#55
I have a cheap gun from Eastwood with no choice of Kv.
The major test of large parts will be this week hopefully.
ch2co
Grumpy Old Man
Jan 9, 2013
752
Likes
461
#56
Keepin' the fingers crossed.
You've gotta show us the results right away no matter how bad they are.;)
savarin
Aug 22, 2012
1,562
Likes
1,973
#57
The very first powder coated project.
All the black parts of the telescope stand and I must say I was extremely pleased with the finish and not difficult to do although its a bit messy with excess powder to clean up after spraying even in the booth.
Being gloss black it doesnt show in the photo but everyone who has seen it remarks on the glossy finish.
ch2co
Grumpy Old Man
Jan 9, 2013
752
Likes
461
#58
Wow! beautiful job, and yes I can see reflections i.e. gloss finish. A major accomplishment albeit maybe a bit messy?
Very cool. Congratulations. The first time even!
Charles, AKA the grumpy one
savarin
Aug 22, 2012
1,562
Likes
1,973
#60
Thanks Chuck. I am most impressed with the ease of use.
One lesson learnt is to make sure the hooks holding the items in the oven are strong enough to hold up.
The long section of the stand was held up with brass hook that straightened in the oven allowing the item to fall.
No damage to the oven but it did mar the paint at the top of the tube but it cant be seen as its covered up by the top aluminium casting. Phew!
Container Above bottom breadcrumb
