  • NOTICE: There are two new video channel areas set up, one for staff, and one for subscribing members. You need to create a folder. Then add your media to that folder. Once added, you can cut and paste the code at the bottom right to embed the media into a post on the forum.
    It works very similarly to YouTube, except videos are stored on our server. Click Here For The Video Channels
[4]
Pot and switch types for remote VFD
[3]
[10] Like what you see?
Ropata
Active Member
Active Member
May 24, 2016
110
Likes
29
#1
Hi Guys,
I want to wire in some on and off push buttons and speed control pot to this cheap 2hp VFD I am about to hook up to my new belt grinder. I just want the unit away from the dust and have a smaller better looking panel to control from. Can anyone please give me some advice about what rating and size etc for the pot and buttons?
gr8legs
H-M Supporter-Premium Member
Oct 31, 2014
209
Likes
283
#2
Most VFD control circuits are low-voltage low-current and any switch will work fine.
The potentiometer resistance value you get depends somewhat on the input resistance of the VFD control, which is usually in the specifications. A general rule is the pot resistance should be 1/10 of the input resistance of the circuit so it appears as a voltage source to the VFD input port. Typically the input resistance of the VFD is 10K ohms, so a 1K or so pot would be appropriate. Check the VFD specs and purchase accordingly.
The power rating of the potentiometer is an Ohm's law calculation: Power=Voltage squared divided by resistance. That calculates the actual power dissipated by the device, prudence dictates getting a pot rated at least twice the power dissipated as a safety factor.
Have fun!
Stu
Uh oh - seems I have double posted and cannot figure out a way to delete the doppelganger. Editing, no problem. Deletion? I can't find that button!
Ropata
Active Member
Active Member
May 24, 2016
110
Likes
29
#3
Thanks Stu. I can't seem to find anything in the badly translated manual. It seems quite a popular model. It's the same one that Banggood have been sending out to Youtubers to test. Here are some photos of the relevent pages I think. Does it look like I need to install jumpers if using a remote pot to you?
Karl_T
Active Member
Oct 14, 2014
825
Likes
292
#4
it does look like you jumper 1 and 2 for external rheostat pot.
cannot quite read the value on page two. You could just try a 5K one.
Yep most any small switch will do.
CluelessNewB
Active Resistor
Mar 3, 2013
1,014
Likes
498
#5
That looks like a Huanyang VFD. The manual that I have for mine shows a 10K ohm potentiometer. You will want a linear taper potentiometer rather that an audio (logarithmic) taper. (All of the Teco VFD's that I have seen also use 10K ohm pots)
KMoffett
Active Member
Jan 18, 2013
343
Likes
68
#6
For momentary push buttons, you will have to add relays. Attached is the configuration for my remote. Probably a bit more than you want. I jdidn't have reverse because it was for an auxiliary high spindle that was never going to need reverse. What functions do you want in the remote?
Ken
CluelessNewB
Active Resistor
Mar 3, 2013
1,014
Likes
498
#7
If it's like my Huanyang VFD it supports "3 wire control". I assume for a grinder you don't need reverse. Two momentary buttons should work, a RUN button that is NO (normally open) and a STOP button NC (normally closed). No relays are required for this VFD. The controls are low current/low voltage so electrically just about anything will work. You may want to look for something that is mechanically strong and sealed well for dust. If you don't need reverse the NO (normally open) button connected to D2 in the diagram below is not required.
Bob La Londe
Active Member
Active Member
Apr 19, 2014
282
Likes
170
#8
Most belts are directional, but I have seen some belt grinders built to be reversible. I guess you can always flip the belt around.
Bob Korves
Jul 2, 2014
4,188
Likes
4,375
#9
Hi Guys,
View attachment 248979 View attachment 248980
On my B&S surface grinder, I installed the same basic VFD as you are using, only 2.2KW (3 HP) and without the potentiometer. Only $10 more on eBay than the 2 HP version. I installed the VFD in a project box after cutting round holes in the top and bottom for a muffin fan (top) and filters (top and bottom). The fan has a sheet of thin polyethylene on the top to also help keep grit out. The poly bends upward when the fan is running, and settles back down when the fan stops.. I removed the front covers of the VFD completely, and then removed the display/control panel from the front cover. I mounted the display/control unit to the front of the enclosure and added an oak frame for looks. The wiring tape from the VFD to the display reaches easily. There are also remote controls for spindle speed and spindle on/off installed in the front cover of the project box. They are programmed to control the VFD. Since I got this finished, I have never touched the buttons on the VFD control/display, which are known for being less than robust, and will only use them if and when I need to reprogram something. The added switch and pot are cheap and easy to replace if needed, and AFAIK spare parts are not available for the cheap Chinese VFDs. The remote controls are also a lot nicer and more convenient to use. It works good.
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,353
Likes
3,596
#10
Hi Ropata,
you are going to need maintained contact or latching switches for the VFD you have chosen.
i installed the same type of VFD on my shenwai sw 900b, but mine is the 2.2Kw (3hp) version
a 10K potentiometer will work fine.
as far as switch rating is concerned, the voltage and amps are low when you use the DCM power
24volt/ 5 amp rating would be more than sufficient for the switches
Bob Korves
Jul 2, 2014
4,188
Likes
4,375
#11
Hi Ropata,
Yes, Mike. At first I misinterpreted the poor installation manual drawings, understanding the wiring diagram to require momentary switches. Turned out that was wrong... Maintained contact (on/off, like a house lighting wall switch) or latching (for power outage safety) switches are needed.
Ropata
Active Member
Active Member
May 24, 2016
110
Likes
29
#12
Hi Ropata,
Thanks Ulma. And am I correct to have to install the jumper on the J1 connectors?
CluelessNewB
Active Resistor
Mar 3, 2013
1,014
Likes
498
#15
If it's like my Huanyang you may use momentary switches but maintained switches will also work.
KMoffett
Active Member
Jan 18, 2013
343
Likes
68
#16
If you want:
Speed control...Pot
Forward-Reverse...Toggle or Rotary Switch
Start... Mom Push button
Stop... Mom Push button
The DPDT toggle shown shown has a center-off position so switching between forward and reverse shuts off the drive, and requires pressing Start again.
Different manuals vary in whether the VFD has +12VCD or +24VDC to power the remote relay.
K2n
Cadillac STS
Jul 20, 2012
512
Likes
160
#17
For the 10k pot get a 10 turn pot. Takes 10 turns from 0 to 10k. That way you get better smoother control of your speed.
CluelessNewB
Active Resistor
Mar 3, 2013
1,014
Likes
498
#18
I don't understand why you would want to complicate it by using a relay. This VFD out of the box is designed to use 3 wire control just like a typical motor starter which consists of a Normally Open Momentary "Start" Button and a Normally Closed Momentary "Stop" button. There are some VFD's that do not directly support 3 wire control, the Teco FM50 for example but this is not one of them. The diagram above in post #8 is from page 37 of the owners manual that I have. It is exactly how my Powermatic 30 belt sander is hooked up (except I didn't bother with the reverse button connected to D2). It has a momentary buttons as listed above. The one I have is a 2.2kw Type - HY02D223B
KMoffett
Active Member
Jan 18, 2013
343
Likes
68
#19
Even though the manual for my Huanyang shows the D1/D2/D3 Fwd/Rev/Stop schematic with momentary push buttons, it didn't work that way in the actual controller. Also the +24VDC output was available in my controller, but not in the manual. I have at least 4 different manuals, purported to cover the same controller, but with different control terminals.
Ken
[6]
[5] [7]
