- Sep 9, 2014
- 90
I occasionally have a project where a collet would be useful in my lathe. I have a 5C collet closer for it, but the setup takes too long because of the spider on the outboard end of the headstock. Everything needs to come off, including the lathe gear cover, spider, the chuck and then back on which can take up an hour or more. It's not worth the aggravation for a quick one off job that's too small for the four jaw.
After some thought and looking at the cost of a collet closing chuck, I chose to make a “poor man’s” collet chuck. I had an ER 40 R8 chuck that was searching for a purpose. I also have a fairly good set of ER 40 collets.
I set up the chuck in my four jaw, cut the R8 mount off the ER 40 chuck and bored out the back end of the chuck so stock of up to one inch would pass thru. With the spider for outboard support, I can work with stock of up to about three feet, depending upon diameter.
Now I dial in the ER chuck in my four jaw ( ten minutes or less) and I'm off and running. The TIR is + or – 2 ½ tenths, repeatable.
One caution, those chucks are really hard. I used a carbide cutoff and boring bar for the work.
