PM935 T-slot Width Variances
kb58
Jan 10, 2019
1,042
This is more a public service notice than an outright complaint, though it does make one wonder.
I bought 5/8" Kurt vise keys for their 6" DX6, thinking that it would be an accurate and easy (though not cheap) solution to keying the vise to the center T-slot—hah.
The PM935 manual does recommend vise keys, but notes, "...The T-slots on PM TS and TV mills are nominally 5/8", but check before working on the keys." Good advice, because the two outer T-slots measure 0.626", but the center slot, the one I wanted to use, measures 0.618". Did they use a different cutter on only the center slot(?), or were they just sloppy? Obviously, it's not hard* to mill down the keys to fit, but one has to wonder what that did at the factory.
If I had followed the manual and measured the center slot first, I wouldn't have bought these keys. Oh, and I did consider mounting the vice to one of the outer slots, but it ends up too cantilevered for comfort, and probably affects accuracy.
* Well, it might be hard, literally, since the keys are probably heat treated.
Store bought t-nuts are hardened and often not nicely finished. The sizing of t-nuts is nominal at best, but so are many t-slots. I make my own t-nuts from mild steel to the fit I prefer, and round all edges and corners carefully. t-slots are a precision part of the machine, and should be cared for just as well as the ways and table surface. The hard t-nuts can be hard on the t-slots, they cause wear and galling. In my opinion...
I suppose the factory cuts the initial slot in more than one pass, before using the t-slot cutter. Probably normal variation for import machines
Possibly you could recut the slot using the machine itself but I would hesitate to do that
Mark
+1 :)
I would expect that the center slot was cut undersized for precision grinding to final size and perhaps the slot wasn't ground?
I wondered that myself, but will cut or grind down the keys instead!
Good point. I did use WD40 on the center T-slot, hoping that it would open it up... nope. Before doing anything else though, I'll use a stone and run it down the sides to remove whatever else is in there. Since it's about 0.006" undersize, that's only 0.003" per side, so "maybe" it's paint or a rough coating. Fingers crossed.
To finish this thread, I spent about five minutes on each T-nut, rubbing them over a stone just enough so they'd drop into the slot. Problem solved.
