PM25 Owners
wrmiller
Chief Tinkerer
Mar 21, 2013
4,063
So I just ordered mine today and was wondering if it will show up in two boxes or one?
Anything in particular to look for during setup?
Thanks,
Bill
They have been showing up in two boxes, but Matt can confirm that. They also come through very clean without all that excess cosmoline gooped on. A good easy cleaning and follow the break in instructions and you will be off and running pretty quickly. The breakin run helps set the bearings and allows everything to run up to operating speed and temps. After a month I believe an oil change is recommended and an annual change thereafter. Again Matt will be glad to answer all of those question a lot more authoritavely or Ray C may come along and help you out too. Ray helps Matt on this site to insure any issues are addressed and all questions are satisfactorily answered as quickly as possible. Hope this helps.
Bob
In virtually all mills, the base/stand and main unit each come in their own container. If you purchased accessories, they are usually packed inside the crate with the main unit.
Clarification: By base, I mean the stand. The table is a part of the main unit.
Ray
Thanks,
Bill
Thanks guys, info appreciated.
Oil change?? I thought these bf20 designs were a dry head?
Bill
Bill... in researching a decision btw a LMS3960 and PM25, I see you had the 3960 and recently bought a PM25. Would you mind sharing your thoughts on pros and cons of both?
Thanks in advance,
Henry
Hi Henry,
When I decided to purchase the PM25 I thought I would sell the LMS, but have decided to keep it instead. I've never had a second/backup machine, but I have already made parts for the PM on it's little brother. :)
The reason I bought the PM was because I wanted a slightly larger machine. I REALLY wanted the PM30L, but I wasn't sure I could handle it by myself.
The biggest advantage the PM has over the LMS is size of course. While I don't have farm implements to repair, or need to make custom parts for a hot-rod/Harley build (I wish...), I found the LMS a bit on the small side for some things I do. The PM is literally the LMS' big brother. The LMS weighs under 150 lbs with a vise and DRO scales on it and I can pick it up and move it by myself with no hoist or other assistance.
The PM weighs almost double that, and I bought a one-ton shop hoist to lift it onto the tool box. Can't quite pick this guy up with my bare hands. As most of the Big Iron guys here will tell you, bigger is better. Mass really does make a difference, if you can afford or have the space for it. I have neither, and honestly, wouldn't begin to use the capability of a BP or a 14x40. But...having twice the weight/mass behind a 1/4" or 3/8" end mill makes a world of difference.
Advantages/disadvantages? I guess this boils down to opinion, but I'll list mine and you can decide for yourself if any of it is worth a hoot. ;)
LMS:
Small(er) footprint, yet capable of some very accurate work as long as you stay within it's intended work envelope.
At first I hated the rack gear on the Z-axis, as it can move on you while you're cutting if you are not careful. But after installing a 3-axis DRO and the Air Spring, that became more manageable. Now I have become accustomed to it and actually like being able to 'rapid traverse' the head up and down when I'm changing end mills or drill bits.
20 TPI leadscrews on X and Y axis. These allow for very small precise movements. Once the DRO was installed, I came to realize just how small/precise. Of course you have to crank your hand off to get from one side of the table to the other. Tradeoffs... :)
PM25:
Primary advantage and principle reason I bought it is the increased table size and Y-axis travel. I will soon have need of doing some work on a rotary table and wanted a 6". This will fit SO much better on the PM's larger table.
Larger work envelope. While the LMS can do 'most' everything I need, it will be a little easier on the PM. My max work envelope is usually about 4" square, but can sometimes get to 6". 6" gets a little tough on the LMS with it's shorter Y-axis travel.
Power and mass. More is better. Even though I have no need or desire to bury a 1" end mill in a 12" square piece of 4140, I do appreciate the smoother cuts and less vibration I get with my 1/2" and smaller end mills. There are limits to what this machine can do, obviously, but for my pistolsmithing and other projects I am well within the capabilities of this machine as long as I don't get stupid. I knew I was borderline with the LMS, but didn't know about the PM/G0704 types at that time.
The PM has courser leadscrews, so real small movements are more Art than Science, but I am putting a DRO on so I will figure it out. I like having a leadscrew on the Z-axis from a control perspective, except when I need to rapid traverse. I have this vision of putting a stepper motor on it with a manual digital control wheel and a course and fine feed rate. Like my friend's CNC control. Maybe the guys in the CNC forum can help me figure out how to do this.
That's all I can think of at the moment. If you have any specific questions I will try to answer as best I can. I guess it really comes down to what you want to do and how much machine you have room for.
Bill
Thanks a lot, Bill. I'm primarily a woodworker and make duck calls and such. I've been doing a little "milling" on my drill press with an xy table... enough to convince me I can get better consistency if I mill more and cut less. Thus my interest in a small mill is largely wood-driven, but if I'm going to invest in one I want to be able to learn metal machining to make small parts and jigs. I'm trying to get some idea of too small/lightweigth vs too much, and your reply helped a lot. I suspect either meet my immediate needs and the question is whether I'd grow out of the 3960... but I don't have a crystal ball!
I don't have much space, so one thing I've considered is whether having a milling machine would eliminate my need for my DP (a floor standing model). The 3960 is too small for my largest drilling operation (1" drill 5"deep). How well/poorly would the PM25 serve as a DP?
The quill on the PM25 only travels a little over 2". For deep stuff like you're talking I'd just crank the Z-axis handwheel and lower the whole head.
You're talking a 1" wide and 5" deep hole in wood right? The max drill bit size on the PM25 is 25mm or 1", hence it's name. And that's for metal.
Cranking the Z-axis handle is not the same (not as fast) as yanking on a lever on a drill press. I guess it would depend on if your wood/workpiece can handle a drill bit coming down at a slower feed rate.
EDIT: Re-read your post. Not knowing exactly what you're doing and how, I might suggest keeping the floor standing DP. I don't have anything close to your needs and do the small stuff on the LMS.
Bill
Bill
Youre right I was thinking of a different machine when I wrote that. But it is good to follow the manual for all required and recommended maintenance to keep it new as long as possible. Good luck and Happy New Year!!!
Bob
Thanks, Bill... what I suspected, but having not used one thought it better to ask and be sure. Back to my research and a decision.
One last question, since I'll have to learn how to set one of these up on my own. Any input as to whether either would be simpler than the other for a newbie to set up, maintain, and learn on?
