- May 16, 2016
- 1,693
I've Sent Matt a deposit on a 1340GT with 3 phase motor planning on adding a VFD to it. BUT, noted later that the switch between high and low range requires change of the belt drive which the way I read it is a significant hassle. Also talking to my electrician friend who will wire it up for me it's going to run me close to a $1000 by the time I run power, add the VFD, box for the VFD, make the internal wiring changes required to take advantage of the VFD. The 1440 is chinese not Taiwanese and I'm sure not as nicely done but does come with a simple plug into my existing wiring, DRO, variable speed drive, a lever to change from high to low range and a 2" spindle bore. I've a friend with a chinese 1236 and one with a grizzly 1440 both are happy with them.
I'm a bit anal about stuff, like it neat and nice but am having second thoughts about giving up spindle bore, and DRO and over $1000 difference in the end to end up with a "nicer" but perhaps somewhat less capable lathe
Thoughts anyone? AND, thanks for the time to read this far.
Alex
These are always difficult and controversial questions. Fact versus fiction and personal opinions always makes for much discussion. I personally don't think I'll ever buy another Chinese machine, The few I have bought I have always regretted. Sure the Taiwanese price is usually about 25% higher but I think you get at least 50% better quality and therefore value.
I ended up buying the Liang Dei 1216, which is apparently made in the same factory in Taiwan as the Taiwanese PM machines in fact the LD1340 appears identical in every way to the PM1340. Just a different name on the face plate. The PM brand does not appear top be available here in Australia, the local dealers just bring in the LD brand.
Prior to buying my lathe I looked at numerous Chinese machines, but was always disappointed in the quality or lack of, particularly in the finish and feel of the machine, so ended up with the Taiwan model, and don't regret the extra cash, quite happy with it.
Single phase or 3 phase. mine is only single phase 1.5 HP. I certainly don't need any more power. VFD or not. I've never used one adn don't see the need and can't justify the cost. The braking with a VFD is not really fast enough to save your arm. so what's the point? Speed control , again I can't justify the cost. I've got enough speed as it is. DRO, again I've never used one and can't justify the cost. I thought we are supposed to be precision machinists here. A DRO appears to me to be and expensive and complicate way to compensate for lack of skill. I put it the same basket as CNC, great for production volume but the skill is programming not machining.
These are all personal choices and decisions here, and at the end of the day you will have to make your own, but and unless you need the extra swing and spindle bore, which you haven't said you do I'd put my money on the 1340, by all accounts it's a very nice machine
