Aaron, the stuff is about as nasty as anything you can imagine. It is a mix of 10 % molybdenum sulfide and 10% graphite in an asphalt base. If it gets on something you have to use a solvents and detergents to get it off. When you say it is black, that doesn't even begin to describe it. Wear some vinyl gloves when you put the stuff on. If you get it on your hands you're going to need a bar of Lava soap to get it off.
If you were to spray it on the gears it is going to make a mess of your lathe. Therefore I brush it on the teeth only and it drys to a waxy consistency that stays on them.
In the photo that I posted you can see that the gear teeth are black and the sides/body of the gears are shiny steel. I did not coat the gear that is not in use and that is apparent in the photo as well.
By the way, one can is a lifetime supply for the lathe.
