- Jun 12, 2014
- 5,055
Was asked to post a video of threading with using a proximity sensor stop. There is no need to disengage the half-nut, so there is no issue with engagement or cutting metric threads, but one can disengage the half-nut if one so desires to manually back up the carriage.
Threading on a lathe using a proximity stop which is integrated into the VFD, is used to control the stopping position of the lathe carriage. The proximity sensor position is set by the micrometer stop, and the stopping position repeatability is ~0.0004" or better even at high feed rates. In this case, every pass hit 0.5000" on the DRO. This is probably due to the use of the VFD 1 second braking and use of an inverter rated motor. My lathe is set up with a single belt speed using a 2.5" motor pulley and the low speed 5.5" stock pulley. Inverter motors can maintain full torque down to 0 RPM, and full Hp out past 2X their base speed. Braking is very accurate and quick. The default setting is 3 seconds, but the E-Stop and proximity sensor default it to 1 second automatically. Also because of the use of the low speed pulley ratio, the applied Hp to the spindle at maximum speed is doubled. The speed usable motor speed range is 20-120Hz, so something in the range of 40-1800 RPM with 6 mechanical gears. In practice I usually use 2 or 3 gear settings most of the time.
In this example I am cutting a 3/8-24 thread in oil hard drill rod with a Dorian thread cutting insert at 250 RPM. When treading a 0.1" relief grove is cut to approximately the depth of the final thread, the thread cutting insert is placed in the center of the relief and the cutter insert point advanced to the depth of the final thread cut. This is then used to set the lathe proximity carriage stop position, the tool post slide dial is set to 0 (the position of the cutter is expected to be in on the final cutting pass). The lathe cross slide is locked, and only the tool post slide is moved from this point forward.
When threading there is no need to disengage the half nut for each pass, at the end of each pass the cutter head is backed out with the tool post slide, the machined reversed by engaging a proximity bypass button, and then the tool post slide advanced to the next cutting depth and the next pass is taken. It is easy to cut a full thread in about 2 minutes with high RPMs and with no worries.
