PM1236 3phase motor VFD upgrade
jonathank
Feb 1, 2012
9
Initial power wiring of the VFD
wiring up the VFD for the motor
powering up the motor
mounting and dialing in the pulley
motor mounted and powered up
original 220 lathe wiring
forward and reverse switch
original lathe controls (220)
new 5v control wiring
potentiometer wiring (switching the 2 outside wires reverses the pot)
all wiring done minus the potentiometer
alll the new wiring on commoning blocks
all the wiring on the VFD
control panel back on with potentiometer knob
finished up
heres some videos I mode of my progress
http://www.youtube.com/watch?v=hPxxMprrQLw
http://www.youtube.com/watch?v=7jgSEb3TYDg
http://www.youtube.com/watch?v=ZZO_snyQcfQ
http://www.youtube.com/watch?v=4YOZHcoSNfQ
http://www.youtube.com/watch?v=2hNK10rw_mk
Looks like you have done a fine job.
also appears you have alot less wiring with the new 3 phase stuff, you gotta like that, ;)
Your going to like having the vari-speed with the VFD
Just curious, where did you get the motor and what type is it?
HP
2
RPM
1750
Frame
56C
Phase
3
Voltage
208-230/460
Service Factor
1.15
Full Load Amp
6.84/3.42
Hertz
60
Efficiency
76.0%
Enclosure
Totally Enclosed
Overload
None
Rotation
Reversible
Shaft Size
5/8”
Weight
48 LBS
Warranty
24 Months
NEW 2 HP 1750 RPM 56C FRAME 208/230/460 Volt Totally Enclosed Fan Cooled Three Phase Electric Motor. Removable Base, Inverter Duty(5:1 VT/2:1 CT
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=290686153940&_trksid=p2992.m753
One issue I ran in to with this upgrade was the placement of the power wiring box on the motor. It sits on the bottom side of the motor when in place on the lathe and I had to make a flat cover to get it to fit...If I had it to do over, I would have payed more attention to where the wiring box is located when I was motor shopping.
Jonathank. I know this is a very old thread but i am curious how the upgrade has worked out over the years?
Thanks, Joe
