Could someone who already owns a PM1127VF-LB Lathe measure the actual depth dimension from the wall to the front most handle or whatever is farthest from the back if the machine was pushed back against a wall. I know that the data sheet indicates 27.5 inches but I have been told the actual distance may be shorter than this. Also if the machine was mounted on the factory stand, would the gear cover open if the lathe was against the wall or how far out from the wall would be required to open the side gear cover to change gears. THANKS
