PM Brand DRO any reviews
JBowlin
Jan 10, 2017
32
Ok so I'm ready for DRO. I emailed Matt at PM and he has 2 options, the Easson 12b and the PM branded DRO. Both I assume include glass scales. Has anyone used the PM branded one? It's 100$ cheaper than the Easson and both are considerably cheaper than DRO Pros with magnetic scales. Don't mind spending the money but don't want to if not warranted.
You have not mentioned the application, which to some degree may affect what you choose. I have had a number of DRO's, I have the previous Easson ES-12 on my lathe and a a DRO Pros El700 on the mill. Given the costs, I would recommend the ES-12b with glass scales. A good glass scale with a decent cover will hold up very well, unless you are using flood coolant or have a very dirty environment. I like the graphical displays and the soft keys on the Easson, the EL700 is a touch screen and easily gets confused when you have greasy or dirty hands. The magnetic scales are easier to install then glass scales, and can take a bit more runout, but it is not difficult to get the glass scales setup correctly. Once the scales are mounted you are done. Given the technology, magnetic scales should be less, maybe in a few more years.
There are a few places where a mag scale nay be better, where you are limited in space or you need an odd sized length, I used them on my mill because of the mounting configuration and I needed a very shallow scale for my spindle. I still feel that the glass scales work just as well, and I prefer the Easson display and the functions are well laid out. The next step up is the EL400 with magnetic scales at close to twice the price,
I sure enough forgot to mention that it's going on a new 1340gt.
Thanks for the info. I think PM has a kit with glass scales that's a direct fit for this machine, right?
I have the ES-12 with glass scales on my 1340GT that I purchased from QMT, so yes they can provide correct sized scales for this machine. You will need to discuss with them what mounting hardware/brackets come with each kit, in most cases you end up fabricating most of it. These are some old threads on different DRO scales/mounting. The cross slide glass scale covers the lock so you need to either put a lock on the other side, or machine a scale spacer and mount a small metric bolt that you can get access to with a wrench. Magnet cross slide scale could be mounted so you can still have direct access to the cross slide lock.
http://www.hobby-machinist.com/threads/installing-dro-on-pm-1340-gt.48653/
http://www.hobby-machinist.com/threads/another-pm1340gt-build.52267/
http://www.hobby-machinist.com/threads/ghb1340-dro-install-carriage-scale-mounting.52444/
http://www.hobby-machinist.com/threads/dro-advise.46301/
