Hi everyone. I bought a PM-940 cnc a few week or so ago and have been having trouble setting it up. I think I have about everything working (at least enough to run some gcode). However gcode seems to be the problem! I can jog the table and z all over the place, but if I turn control over to Mach3 it jumps every second or so. I can do a simple G0 move, or just tell it to go to zero. Either way it jumps.
IT has nothing to do with position, as I can change the speed of the motor and make it go a little further before it does it. It ALWAYS seems to do it about 1sec after I start the code.
For my settings please refer here http://www.hobby-machinist.com/threads/pm-940m-cnc-pre-assembled.49011/page-2
My settings are identical to Cut2cuts's. Since you cannot see the motor tuning section I am running 60ipm and 10in/sec/sec. And I have tried all the way up to 100/10 all the way down to 10/.5 and it still does it after about 1 min. BUT IT WORKS FINE IN JOG?
What am I missing here?
Edit: I should also add that when I am running very slowly (10 IPM) you can actually see the DRO stop as well, but it doesn't loose steps because it's moving so slow...
PZ
PZ
