Hi everyone.
<o</o
As described in the other thread, I made no secrets that I did not like handle to move gear head on my PM-932M-PDF.
<o</o
This project took longer then I expected mostly dreaming up shapes of brackets, adjustment of chain tension and waiting for components ordered on eBay.
<o</o
Today after experimenting with different sprocket ratios, I found 12 teeth on 1 to 1 AnglGear and 30 teeth on gear head shaft to be reasonably satisfactory.
<o</o
Turning the wheel is effortless and control of gear head movement is smooth enough to slowly dial 0.0002 increment, standing in front of the mill, comfortably watching the DRO.
<o</o
Here is a short video:
http://www3.telus.net/oceanready/PM-932M-PDFgearheadcontroll.avi
One full turn of the wheel moves gear head 0.047” and the wheel is 9.5” in diameter. The shaft from the wheel to the gear is 5/8” W-1 drill rod. If I would do it again I would opted ¾” as I can feel slight torsion twisting. I may even change that one day. I will likely make a dial on the wheel, but I may still play with the ratio in the future.
<o</o
Should someone wish to duplicate this modification, be aware that in PDF mode wheel will turn as it is directly connected to the shaft.
<o</o
Next thing will be to make a mold and lay up fiberglass cover for the chain, to keep the chips out.
<o</o
Regards to all,
Radek
<o</o
<o</o
<o</o
<o</o
<o</o
<o</o
<o</o
<o</o
Regards to all,
Radek
