    Dismiss Notice
Pm-727m Face Plate
Discussion in 'PRECISION-MATTHEWS' started by 3dshooter80, Jul 4, 2016.
  1. 3dshooter80
    3dshooter80 United States Master of Metal Malpractice Active Member
    453
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Looking for any input of removing the face plate on the PM-727M mill. In particular, I'm not able to
    removed the L/H selector knob nor the 1/3/2 selector knob. I loosened (to the point of removing) the set screw in each one, but they don't seem to want to budge.
    Wondering if there's a lock ring in there and if so, how do you get to it.
    For those that just have to know "why", I want to see how the DRO is mounted for possible replacement with an iGaging DRO so that I have all 3 axis on one display (TouchDRO/Android). But, that is not the jest of my query - I simply need to know how to remove the face plate.
    TIA,
    Lee
  2. jclouden
    jclouden United States H-M Supporter - Premium Content H-M Supporter-Premium
    34
    13
    City:
    Front Royal
    State:
    Virginia
    -Return to Top-
    There are 2 set screws threaded on top of each other in each knob. Be careful not to drop the ball bearings that seat into the detent on the faceplate behind the knobs. There may be more than 1 ball bearing in each knob. Also be aware that the 2 set screws appear to be used to adjust the tension of the knobs against the faceplate.
    Jon
    Sent from my SM-T700 using Tapatalk
    brav65 and 3dshooter80 like this.
  3. 3dshooter80
    453
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Thanks Jon - didn't think to check for 2 set screws. I'll check it out this afternoon.
  4. 3dshooter80
    453
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Jon, that's exactly what I needed to know. And thanks for the heads up on the ball bearings. There are 2 sandwiched between each knob & the housing. I will most likely video the DRO replacement when I start that project.
  5. MattK
    MattK United States Iron Registered Member
    1
    3
    City:
    Chicago
    State:
    Illinois
    -Return to Top-
    Hey 3D (or anyone else with a 727) Were you able to determine if you can get an iGauging scale mounted?
    I'm curious myself too. I'm waiting on my 727v to arrive so not sure just by looking at pictures.
    I ordered 3 iGauging scales (EZ-View Plus) for X,Y, and Z which I intend to use with TouchDro. I want to replace the quill dro with another so I can sum the quill + z together.
    edit: sorry for conjuring up an old/dead thread. I misread the year. found this in a search for "touchdro".
  6. tweinke
    tweinke United States Active User H-M Supporter-Premium
    234
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    I just got my last two scales to do the same thing you are with touch dro. by eyeball the iGaging read head will be a tight fit in the hole but close in size to what is there. The original poster of this thread does not appear to be here anymore probably due to a technical glitch that merged all his posts with 3d shooters posts. I do know he was able to mount the scale on his 727 though. If memory serves me right he has a video on utube his name is Lee Peedin [ Tin Barn Time]
    ng
  7. MattK
    1
    3
    City:
    Chicago
    State:
    Illinois
    -Return to Top-
    Thanks for the quick reply. I'll take a look.
  8. MattK
    1
    3
    City:
    Chicago
    State:
    Illinois
    -Return to Top-
    Couldn't post links in my last reply.. Looks like I found it:
  9. tweinke
    234
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    That's it. Look over some of the projects he has done if you have some spare time. On my 727m I'm not worried about getting the read head behind the faceplate like he did
  10. MattK
    1
    3
    City:
    Chicago
    State:
    Illinois
    -Return to Top-
    I'm in the same boat.
    Interestingly, he just posted another video today. Looks like he switched it back to the stock scale. I wonder why that is. You can see that he added a shim where the scale mounts to the collar, as well as the the two screws he had in place for the cover plate.
  11. tweinke
    234
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    Think he made a comment in one of his videos that he got a killer deal on that DRO, he is still using Touch DRO on his lathe. If I remember correctly he milled that collar shorter so he could get the read head under the face plate. I set my 3in1 up with iGaging scales and aMSP430 touch DRO setup and have been pretty satisfied with the results. The accuracy is pretty good and I'm sure for a bunch more money with glass scales would be even better but in my case dollars do have to be counted carefully. Sure does beat having to count hand wheel turns and remember all that.
Share This Page
