    Dismiss Notice
Pm 1440-hd Heavy Duty Lathe
Discussion in 'PRECISION-MATTHEWS' started by rbjscott, May 4, 2015.
  1. rbjscott
    rbjscott Active Member Active Member
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Mid August is projected date. Hoping for smooth delivery.
  2. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Does anyone know the spindle height from the floor of the 14X40 HD. Thanks!
  3. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Received an e-mail today saying that my 14X40 had shipped, The wait was longer than expected, hope it will worth it. I am really looking forward to the lathe.
  4. wrmiller
    wrmiller Chief Tinkerer H-M Supporter-Premium
    920
    113
    City:
    Sierra Vista
    State:
    Arizona
    -Return to Top-
    That is good news! :aok:
    Please post some pics of that bad boy once you get it. :)
  5. bkcorwin
    bkcorwin United States Active User Active Member
    5
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Any more updates on the new arrival? I am going to be upgrading lathes in 4-5 months and the 1440hd is on my list.
  6. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    The lathe arrived with no problems, crate not damaged. Roadway did a great job! Well the lathe is even pretty to look at. I have leveled the lathe and have been learning the controls. I am running the spindle at different speeds un-loaded as well as the gear box. This is in addition to the recommended break in procedure. Made a few cut s on Al. Friday to see how the DRO works, never used a DRO before. The headstock is quitter than I expected. And the change gears are also smooth and quite. I am going to make some test cut on steel (drill pipe) this week-end. I am more than pleased with the lathe. Long way from a 13 inch South Bend that is now for sale.
  7. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Also need to state: Quality Machine is top notch, did and proved what the said.
  8. wrmiller
    920
    113
    City:
    Sierra Vista
    State:
    Arizona
    -Return to Top-
    Dude, you gotta post some pics! :)
  9. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Loading…
  10. tmarks11
    tmarks11 Active User Active Member
    181
    43
    City:
    Port Orchard
    State:
    Washington
    -Return to Top-
    try reposting that. I don't see a picture, all I see is a little red X.
    If you need a place to load your photos to so you can link them here, I recommend photo bucket.
  11. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Been learning the lathe, cutting a lot of air breaking it in. I am going to purchase carbide insert tooling this week--time permitting. I am going to get help learning to post pics next week.
  12. bkcorwin
    5
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Any updates? Curious to know how you are finding the 1440hd lathe.
    Pictures?
    Thanks!
  13. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Have not had time with the lathe. Been doing some work on airboats. Followed a 572 inch Dart engine build--made 701 HP at 5200 RPM (bad boy) Right now I have to decide if I want to keep my AXA QCTP or use the BXA size that came with the lath. I have a lot of tool blocks for the AXA, 2 expensive insert holding blocks that I like to use.
  14. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Forgot to say thanks for follow this post. I am really happy with the lathe so far.
  15. bkcorwin
    5
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    updates? Pictures? Its still on my short list.
  16. Klaus
    Klaus United States Swarf Registered Member
    0
    1
    City:
    El Paso
    State:
    Texas
    -Return to Top-
    Helo together,
    I bought mine in 2006/2007 and I was a little bit disapointed. I bought it with the a lever style collet closer installed, which wasn't. There was not much help from Matthew either, so I had to figure it out by myself.
    Also the lever for the feed directions is a pain in the ass to operate, because it's difficult to get into the notch.
    The tail stock quill is way to sloppy.
    The plate underneath the the tail stock is not clamping right either
    I forgot to mention that the feed selection lever at the carriage is very difficult to operate/change from longitudual feeds to cross feeds
    Best regards
    Klaus
  17. bkcorwin
    5
    8
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Interesting. Can you take pictures that show the issues you are talking about? I am curious about how much slop you are seeing in the tailstock quil.
    brian
  18. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    I have a question. The 14X40 HD manual calls for Mobil DTE Heavy Medium oil to lube ever thing. I have not run a machine that did not require Way oil for the carriage and cross feed. Is this common for PM lathes, Any comments about not using way oil. Thanks Folks.
  19. mksj
    mksj Active User H-M Supporter-Premium
    1,279
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    No expert here, but from what I have read and used, I would see no reason not to use Mobile Vactra #2 oil or Shell Tonna S2 MX 68 on the way sliding surfaces. I notice a big difference in using way oil vs ISO 68 lubrication oil that I use for the gearbox and bearings. Some machines specify ISO 68 all around, as it may be easier to use/stock one oil. If that is the case, then the Shell Tonna would be the best fit. Otherwise would use the Vactra #2 on the lathe ways. Evidently Vactra #2 is less tacky then the way oil it replaced which was Mobil Vacuoline 1409, but is less likely to get gummy over time. Vacuoline 1409 also EPA issues with the tackifiers, and there were issues with CNC type machines due to the increase carriage speed.
    This is not specific to the PM/QMT machines, as other machines (like the PM1340GT, ERL, TRL) specify different oils. Your machine looks identical to the Jet GH-1340 and 1440 models, their manuals specify ISO 68 oil for everything. Other manuals specify something like Mobil Vactra Oil No.2 oil for the ways. Grizzly on many of their lathes just specifies ISO 68.
    Example for G0776:
  20. Klaus
    0
    1
    City:
    El Paso
    State:
    Texas
    -Return to Top-
    I'm currently not at home, but as soon i'm back I try to make some pictures
  21. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    I have not found the tailstock Quill to be sloppy. Did you check the clearance.
    My lathe does look like a Jet GH-1340 and 1440 models and the motor is Labeled JET---Go figure. If it is the same, seems to be a good buy from Quality Machine.
  22. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    I have been using the lathe making a few small parts. Two shafts to build an elastic bandage wrapping machine that weight lifters use to re-roll
    ace type bandages. Used the lath to cut " Birds mouths" in some pipe couplings for welding to 1.75 tubing. Learning to use the DRO. A DRO makes setting the tapper attachment easy.
    Does anyone know how much oil the Head stock holds-- just a rough idea?
  23. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    have been working the lathe turning a chuck adapter for a new 3 jaw chuck that I have. Just to see, I took a few cuts at .250 per side.
    Still trying to learn how to posy pictures.
  24. jbolt
    jbolt United States Active User H-M Supporter-Premium
    856
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Anyone have a picture of inside the drive gear cabinet on the head stock? I'm curious on how easy it is to do gear changes with the full enclosure?
    Thanks,
    Jay
  25. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    Send me your E-mail address. I have a couple pictures I took with the cover off when I changed the oil for the first time. I also needed to drill two holes to mount a chuck guard on the head stock. Wall thickness was unknown. Are you having problems with the head stock or gears?
  26. jbolt
    856
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Thanks. I sent you a PM with my email address. Also if you don't mind... can you tell me what the length of the spindle is through the head?
    Jay
  27. qualitymachinetools
    qualitymachinetools United States Active User H-M Supporter-Premium
    248
    43
    Pittsburgh, PA
    City:
    Pittsburgh
    State:
    Pennsylvania
    -Return to Top-
  28. jbolt
    856
    113
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Thanks Matt!
    A safety switch in the door? Really? Like the rest of the machine isn't dangerous. Must be a lawyer thing...:rolleyes:
  29. wrmiller
    920
    113
    City:
    Sierra Vista
    State:
    Arizona
    -Return to Top-
    I love machine porn. :D
  30. rbjscott
    4
    8
    City:
    Dayton
    State:
    Texas
    -Return to Top-
    The spindle is approx. 21 3/16. I am having trouble sending pics. They keep being rejected by Comcast (mx30@comcast.com) ???
Share This Page
