I want the carriage feed screw clutch tightened. Seems too light; as tool just starts cutting you hear and see the clutch slip 2 to 3 times before continuing into the cut. Very small amount of hand drag on the carriage hand feed wheel,(dial), while tool is in the cut will cause the clutch slippage. Thought I'd ask before doing something I might regret. Ideas on this most welcomed!!!
