- Jan 7, 2016
- 3,261
I attempted to correct an error on my PM1022 lathe the other day, and in doing so, created an even larger problem. I swear this only happens to me. Like trying to dig a well in sand. The deeper and faster you dig, the more sand that just falls in on you.
The cross slide has an indexing mark scribed into it referencing the tool post angle. On my lathe, that index mark was about 1.5 degrees off, and it drove me nuts every time I looked at it. So I figured I would carefully grind it down a tad and fill it it with my TIG welder. What I ended up with was a mess. Apparently there is contamination in the casting, or it is some sort of bizarre alloy, that causes the weld to be porous, no matter how well I clean the casting. My weld area has gotten larger and larger trying to fix an issue from the previous weld. Anyhow, I feel that that part is probably toast at this point.
But, this also has me pondering what else can be done to improve the lathe. (I know what you are thinking..STOP! )
For example, there was a lot of slop (backlash) in the cross feed lead screw due to the cross feed nut. There was supposed to be an adjustment on it, but it was already broke when I got the lathe (not Matt's fault). So today I milled it down a little and screwed an acetal (Delrin) piece to the back side with a hole in it to take the slop out. But this made we ask "Are there better lead screw systems out there? I know ball screw are used on CNC machines, but what about a small lead screw like the cross slide? What other thread system could be used?"
Are there any upgrade/improvements for the cross slide itself?
Would a bunch of time spent hand scraping the cross slide, and tool post ways, significantly improve the operation of the lathe?
I assume that the cross slide gib bearing surface is the flats of dovetail, and not on the "points" of the gibs? I ask that because I discovered after taking this thing apart the gib is really messed up (not even end to end, etc.).
Lastly, just curious what the designation of this lathe is? I know it is similar to the Craftex lathes, but does it have a designation like Seig does with their mills (X2, X3, etc.)?
Please note that I have been very happy with PM and Matt, and these issues were either 1.) created by me, or 2). Matt would be unaware of some of this unless he tore every machine down.
Thank you
Thank you
