    Dismiss Notice
Playing With Autocad
Discussion in 'DRAWING, LAYOUT & CAD' started by astjp2, Jan 31, 2016.
  1. astjp2
    astjp2 United States Active User Active Member
    63
    28
    City:
    Pleasant View
    State:
    Utah
    -Return to Top-
    So I was playing around in autocad 2010 2d, now I wish I could figure out how to do 3d, could someone teach me?
    • elt.pdf
      File size:
      4.8 KB
      21
  2. Cavediver
    Cavediver United States Active Member Active Member
    22
    8
    City:
    Buford
    State:
    Georgia
    -Return to Top-
    Some basic commands:
    Extrude (type ext) creates a 3d object from a 2d closed poly line or spline object.
    Revolve (rev) rotates a closed 2d shape around an axis of your choosing.
    Union blends 2 solid 3d objects together.
    Subtract removes the volume / shape of one 3d object from another.
    Slice cuts a 3d object along a line or a 3 point plane.
    Learn to use your 3d visualzation tools (orbit and the elevation views), and learn how to set the UCS to different orientations.
  3. astjp2
    63
    28
    City:
    Pleasant View
    State:
    Utah
    -Return to Top-
    ok, so from my attached pdf, how to I make the line a poly or spline? and what does that do for me? Do I raise the extrusion or lower it?
  4. jagwinn
    jagwinn United States Steel Registered Member
    3
    3
    City:
    Gaston
    State:
    South Carolina
    -Return to Top-
  5. astjp2
    63
    28
    City:
    Pleasant View
    State:
    Utah
    -Return to Top-
    Thanks for the link, maybe I need to take another cad class, its been 10 years and it was only 2 d...
  6. Fossilbones
    Fossilbones Germany Iron Registered Member
    3
    3
    City:
    Canberra, Australia
    State:
    Outside US / Canada
    -Return to Top-
    Thankyou for the post..extremely useful. One issue though, Chap 24 and 25 or missing. Cheers
  7. awander
    awander United States Active User Active Member
    13
    18
    City:
    Upper Black Eddy
    -Return to Top-
    pedit command will allow you to turn a line into a polyline.
  8. stevemetsch
    stevemetsch United States Active Member Active Member
    5
    8
    City:
    Santa Barbara
    State:
    California
    -Return to Top-
    This may be a little late for you but AutoCAD FUSION is available for free for hobbyists. It is CAD/CAM and is fairly simple to learn the basics. It is made for machinist design and CNC. I have not explored if it outputs 3 view drawings. Give it a try.
    Steve
  9. Cadapult
    Cadapult United States Iron Registered Member
    3
    3
    City:
    Newfane
    State:
    New York
    -Return to Top-
    While Inventor, Solidworks, Pro E, etc. are powerful and are meant for 3D design, don't count AutoCAD out. It isn't parametric like the big boys, but it still works great for 3D. I've been using AutoCAD to design piping systems and structural steel for years now. The lack of some features is somewhat offset by the ease of learning AutoCAD 3D.
    The main commands for creating 3D solids are by creating and combining primitives (Cubes, Cylinders, etc.) and through using commands Extrude, Revolve, Sweep, Loft, Union, Subtract, etc. with closed Polyline perimeters. Change the alignment of the plane you're drawing on by rotating the User Coordinate System (UCS). Remember that extrusions only project out in the Z axis. Use Views (Top, Front Right, Back, etc.) to swivel both your view and the X,Y,Z orientation. Press Shift&Middle Mouse button to rotate your view perspective without altering the current X,Y,Z orientation. Use commands like Union, Subtract, and Intersect to join or carve-out solids. Regular commands like Mirror, and Array can be used to make patterns of features like holes or stiffening ribs. Check out Youtube videos, and the AutoCAD help files for examples of how the commands can be used. I'll be happy to share what I know; just give a shout.
    Cadapult
    jagwinn and JimDawson like this.
Share This Page
