Plastic Gears
mfaith
Jan 20, 2014
19
A little too aggressive with the fly cutter on my G0759. Broke 3 teeth and stripped the inside of the gear. I'm greatful it's plastic. Only a $10 lesson.
Sent from my SM-G930V using Tapatalk
Buy 4...
If you did it once you will do it again..
And at some point part not readily available.
they are a metric modulus gear and similar gearing will be available for decades to come :)
Yes but maybe not that will fit or for 10 bucks...
Factory part is easy drop in where something else may not have correct center and likely more cost.
But may be better and not plastic.
But the plastic broke....what is next touching part and is it better that this gear broke than something else?
Cheap is one thing but having a safety valve is good too just like a fuse reduces damage from short on a wire the plastic gives way to avoid damage to something else.
I have a G0704 with a plastic gear in it and ordered two spares right off the bat, As I know I'll probably need them.
Doug
