    Dismiss Notice
Pipe Sander
Discussion in 'SHOP-MADE TOOLING' started by rdean, Mar 22, 2015.
  1. rdean
    rdean United States Active User H-M Supporter-Premium
    633
    93
    City:
    Weirsdale
    State:
    Florida
    -Return to Top-
    I had a need for a pipe sander for a 6" X 35" column I am making but the price was way over my budget.
    So I went to HF and Lowes and for $15.95 made my own and it really works great.
    Enjoy
    Ray
  2. Franko
    Franko Active User Active Member
    1,004
    113
    Richardson, Texas
    City:
    Richardson
    State:
    Texas
    -Return to Top-
    That's pretty spiffy, Ray.
  3. Johnwright
    Johnwright Wannabe machinist Active Member
    19
    18
    Piney woods of East Texas
    City:
    Palestine
    State:
    Texas
    -Return to Top-
    I presume that the white pulleys are Delrin (acetal). Can you provide the dimensions and the bearing numbers? I have recently had a need for something very similar recently. Good job, especially the price.
  4. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,282
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    A neat solution to your problem. I'll have to file that one away for future reference!
  5. rdean
    633
    93
    City:
    Weirsdale
    State:
    Florida
    -Return to Top-
    The grinder is from HF $9.95 and the sanding belts are from Lowes 1"X42" $5.95 for package of three. The rest of the materials I had in the shop. The plastic is a mystery material but probably acetal. The grinder turns 11,000 rpms so I made the drive pulley the smallest diameter I could safely get away with to lower the belt speed. I drilled and taped the grinder output shaft 1/4 X 20 to attach the drive pulley. The idler pulleys are a little larger with sealed ball bearings but the size is not critical. I thought I may have problems with the belt tracking properly but that is not an issue and the geometry can be quite a bit off before there is a problem.
    Thanks all
    Ray
  6. Johnwright
    19
    18
    City:
    Palestine
    State:
    Texas
    -Return to Top-
  7. Johnwright
    19
    18
    City:
    Palestine
    State:
    Texas
    -Return to Top-
    T
    Thanks Ray, I will surely be putting one of these together. I have some acetal and have been looking for a small project to see how it turns. John W
  8. pineyfolks
    pineyfolks Active User Active Member
    316
    83
    City:
    Dillonvale
    State:
    Ohio
    -Return to Top-
    Good job. Buy the harbor freight router speed control and you'll have variable speed.
    uncle harry and brino like this.
  9. jumps4
    jumps4 Global Moderator Staff Member Active Member
    181
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    nice project
    I could see a lot of uses for that
    Steve
  10. savarin
    savarin Active User H-M Supporter-Premium
    1,688
    113
    City:
    Townsville
    -Return to Top-
    I wish I had seen this some years ago when I wanted a very narrow belt sander.
    Nice job.
    On an aside I wanted to sand the outside of some thin steel tubes so I flipped one of those belts inside out so the grit was on the inside, held the tube in the vice, used a skateboard wheel tight in the drill and placed it inside the belt loop, pulled tight and turned on.
    It took a couple of goes to get the hang of the angles and belt tension but I was soon ripping paint, smoothing welds and the belt contoured around the tube.
    http://forum.atomiczombie.com/showt...inker-and-sander-part-1?highlight=tube+sander
    brino likes this.
  11. rdean
    633
    93
    City:
    Weirsdale
    State:
    Florida
    -Return to Top-
    I will have to try that but I am a little concerned that the power will drop off quickly with the speed reduction.
    Thanks All
    Ray
  12. Tony Wells
    Tony Wells United States Vice President Staff Member Administrator
    19,349
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
  13. fahrphrompuken
    fahrphrompuken Active User Active Member
    4
    8
    S.W.Michigan
    City:
    Schoolcraft
    State:
    Michigan
    -Return to Top-
    Terrific idea, simple and inexpensive. Could think of a lot of uses for that.
  14. Hannadog
    Hannadog United States Iron Registered Member
    1
    3
    City:
    Jacksonville
    State:
    Florida
    -Return to Top-
    Very cool idea & savings! Well done:aok:
  15. gheumann
    gheumann Active User H-M Supporter-Premium
    50
    28
    City:
    Geyserville
    State:
    California
    -Return to Top-
    I've been looking at these. The new cheap chinese ones at $~175 are within reach, but I also thought about building one. Didi you make any drawings you might care to share?
  16. FanMan
    FanMan Active User Active Member
    121
    43
    City:
    State:
    Connecticut
    -Return to Top-
    Nice... I'm visualizing a smaller version, perhaps with a Dremel motor...
    Why three wheels?
  17. rdean
    633
    93
    City:
    Weirsdale
    State:
    Florida
    -Return to Top-
    That was design #1 and design #3 is much shorter and somewhat different.
    The third wheel pivots so that the sanding belt can wrap around the material as it works.
    I do intend to make the plans available in the future but sure when.
    Thanks
    Ray
  18. FanMan
    121
    43
    City:
    State:
    Connecticut
    -Return to Top-
    Gotcha, makes sense now.
Share This Page
