- Sep 25, 2014
- 1,094
Anyone ever seen / used a "Pine Drill Grinder"? I've played with it a bit, it does the basic relieved shape correctly, but seems to burn the ground surface (with the wheel freshly dressed, a light cut and not dwelling in any one spot).
I would like to get set up to split drill points. I'm not sure if modifying this for that task is the way to go, or make another tool for that task?
