- Nov 28, 2010
- 26
My last post under 3 phase motor connection on single phase got me thinking about quick and dirty ways of doing different jobs. The first one that came to mind is removing a pilot bearing from a flywheel. They make a puller to do that. However, there is a cheaper and quicker way to do it which works really well. Turn a dowel, wood or metal, to a close slip fit in the bearing. Fill the bearing with grease, insert dowel, tap with hammer and the bearing will back right out. I'm sure many of you have heard of this, but there are probably many who haven't. I would hope that anyone that has similar suggestions would add then to this post.
John
John
