- Oct 7, 2014
- 6
Hi everyone I finally made a decision to buy the above tool post from Travers in the USA, now I have some questions the original Chinese tool holders are very loose on the post and there is a lot of movement in the handle to tighten it is this normal, I also am thinking I should pull it apart and check and maybe grease it as it does not feel at all smooth when you tighten the handle, are there any adjustments that can be made to help the operation ??? frankly it does not feel much better then the worn out Chinese one that it has replaced
Thanks
Jeff
Thanks
Jeff
