Painting a Kurt vise?
HMF
Site Founder
Administrator
Sep 22, 2010
7,223
Hey Guys!
I bought a used Kurt vise for my mill.
I've disassembled it and cleaned it up a lot, now I'd like to paint it, but I have no idea on what type of paint would be most suitable.
What's the best way to prep it?
As for paint, someone has suggested Brake caliper paint, paint since it is resistant to most oils etc and dries fast too!
Rustoleum rattle can or brush..
strip to bare metal, wire brush, degrease and wash with detergent, wipe down with acetone or lacquer, let dry.
paint on bare metal, no primer.
Only apply any additional coats while initial coat is still wet to tacky or orange peel will occur.
If regular Rustoleum, let it dry for a couple of days.
Rustoleum High Performance paint dries a lot faster.
Re-Read my post.. I am talking RUSTOLEUM !! Different from regular paint.. and yes.. it will orange peel if it is dry and you give it another coat ..(unless you wait a couple of days or so) I am talking about giving it another coat during the initial painting session.. Here is the general rule for Rustoleum: Do all spraying within one hour or after 48 hours .
I tend to use primer with other brands of paint, but with Rustoleum, I find that my results are much better without it. It sticks to the raw metal very well.
Recently, and foolishly, deciding to have an open mind, I strayed from my tried and true method, and regret it.. (This was the result of my reading how primer is a must, results better, etc..).. never again..the finished coat came off from regular use, exposing the primer. Never had that problem with well prepped bare metal.
I am talking bare, raw metal. Not galvanized or treated.
Yes.. I probably should have removed the jaws, and left them bare metal.. I needed to use the vice to rebuild my flywheels asap so decided to just paint over them and remove them at a lated date, which I since have.
I never said primer was not recommended, did I ??
I'm not going to debate this any further.. If you want to use primer, go ahead. I choose not to with fantastic results.
Sometimes if you experiment and veer away from what is written in stone, better results can be achieved.
I will continue to stick with what works for me. Why would I want to do different?
I have painted quite a few machines and vises with Rustoleum. I have found that I get better results when I first use Rustoleum primer. I usually power wash and then degrease with paint thinner via a pressurized air siphon. That usually removes the grease and loose paint. I then give the item a good coat of primer and let that dry at least 24 hours. I then put on heavy coats of paint, usually with a 24 hour wait between each coat.
Later on, the machine or vise has been in use and the paint has been scratched or damaged, I degrease with the thinner and just repaint. It usually matches perfectly with evidence of the repaint. The reality is Rustoleum is pretty good paint and as long as it goes on a clean surface it will usually work with or without primer or special techniques.
The main reason I use Rustoleum is its ease of use and ease of access. There is no magic to using it; and it is very forgiving. I have heard all kinds of stories as to special epoxy paints and what not, but all paint will scratch or get damaged with use. With Rustoleum it is just a matter of degreasing the surface and hitting the spot with some fresh paint.
Randy
Heavy,greasy,rusty and dirty is what most of my hobbies consist of. If you're looking to get back to a good solid surface for paint what I have used is "Easy Off" oven cleaner.It will loosen crappy paint and grease. Usually Cast iron looks like new.
Just need to wipe the surface with xylol prior to painting to remove the flash rust! Then Put the enamel paint to it!
On some of my real crusty projects, I have used pool acid to remove the rust to get it to the clean bare metal.
Chuck,
I use pool acid too when I encounter heavy rust. Just be careful, it will bite you if you let your guard down. You can easily loose an eye or get chemical pneumonia. Easy Off is good for goo, but a good pressure wash( 2000+ psi) will do wonders and allow you to use less chemicals. The resulting surface rust is minimal and easily removable. If you dry it quickly, you won't even get that.
Randy
