My daughter has a gaming machine that won't boot up any longer.
Diagnostic LED's on the board (PartyLan, LP nF4 SLI-DR) show that the CPU isn't being recognized. Won't do a POST, no beep codes, nothing.
All the fans run, but after I did voltage checks I found that all the PSU voltages appear to be a bit low. 5V reads 4.4V, 3.3V reads 3.0V, and 12V reads 11.4V. Searching the web, it appears that this particular brand of motherboard is VERY touchy when it comes to PSU's.
It's a 1000 watt supply, but the voltages look suspect to me - and I don't have a clue as to what the lower "limit" is for voltages on these things. ???
I've been re-seating connectors, swapping memory, disconnecting drives etc., etc., to no avail. What do you say, those of you "in the know"? 8)
[img alt=Reply With Quote]http://bbs.homeshopmachinist.net/images/buttons/quote.gif[/img]
