[How do I?] Odd-shaped stair treads
ProfH
Apr 27, 2017
7
I've a couple of odd shaped stair treads that I would like to install hardwood on. Any advice about the process?
Fixed your picture ;)
I would use some cardboard to make a pattern and cut it out with a jig saw.
I saw your post on CNC Zone, and a tabletop CNC router might work if it is big enough. But trying to model the arcs might be a bit tricky. What I might do in that case would be to take a good picture as a top view, with some known points marked so you can scale the drawing in your CAD program. Then you can fit the arcs to the picture. I have used this technique for reverse engineering shapes that are difficult to measure.
Wrap the risers with kerf-sawn solid or plywood. The treads are usually 1" thick oak.
Thank you Jim for your response! I should have figured it's a smallish community after all .
How about the nose? Should I get one of those lj Smith bendable noses? Or are they no good?
Thank you wawoodman. Can you elaborate on that kerf sawn solid? A quick googling told me it's a technique to use very thin blade to cut wood.. not sure how does that fit/help. Appreciate your help
You just went way over my head. :) Never heard of them. I'm really not a woodwork guy, but a lot of other members here are, and will be able to offer some actual good advice.;)
If you're wrapping around a curve steam or soak the veneer, if you don't want it to split! Once upon a time I bent sides for a guitar by soaking then wrapping/bending around a steel pipe heated by a blowtorch through the pipe, as the wood (mahogany when I did it) dries from the heat it takes a permanent set.
Dave H (the other one)
There are thin plywoods available in 'bending' grades; make a form for your
shape, then bend two or three plywood layers, gluing between them. That will make
the curved shape in a thickish plywood. Veneer a thin (about 1mm) oak face overall,
to matche the tread and other risers.
<http://www.columbiaforestproducts.com/product/columbia-radius-bending-plywood/>
That's for the risers; just edge-join (use dowels or biscuits if you have 'em) to a
tread (standard depth) to make the wraparound step, trimming to the curve with
a router guided on the riser curve beneath.
Woodman's idea of kerf cutting will work great . Saw cut almost completely thru the riser vertically every inch or so and bend it around the curve. Or you can buy a product called bendy ply or wiggle board. bend it to your pattern and glue two pieces of this together and clamp in position. then cover in hardwood veneer. Or
Use 1/4" hardwood veneer and it may bend with ease.
Cheers
Martin
Cheers
Martin
Thanks Martin for the explanation! Does kerf cutting imply anything about the bladder thickness or was that bogus info I read?
