At a customers doing the biweekly maint. foreman came over and asked if I'd look at there Cincinnati cyl. grinder he stated that the work head would turn sometimes and other times he would have to wiggle the face plate to get it to turn, this is what I found a 4 month old bearing and a seal with no seal in it. Now the fun part the spindle has a #5 morse taper I don't have a bull center but my 1/2" Jacobs fit in the hole put some high pressure center lube on it and turned the nose of the spindle so I could build it back up with Devcon plastic steel mixed applied let cure 2 days only 51° in my shop turned it down and fitted a speedi-sleeve, new bearing 5218 shielded, sealed not available , and two seals will be going back to re install on Monday. The bearing was installed by another rebuilding co. they never replaced the seals, even if they had the shaft was so corroded that it would have eaten the seal within days.
