I have a G4003G 12x36 lathe along with a 14" bandsaw, 2x72 belt grinder, 15" drill press, contractor's table saw and several smaller tools needing to be moved from the Bay Area to the Placerville area in the next few months. I will also need to install a 3/4 Bridgeport when it arrives at freight forwarder in Sacramento (details to be clarified later). The lathe is in an industrial building in San Francisco with freight elevator and loading docks and will be installed in my ground level shop with roll-up high lift door.
I would like to discuss details like whether the lathe needs to be disassembled for shipment of whether it can be moved on its bases. I don't have the pallets it came on, if it needs to be taken apart. If this sounds to be of interest to any members or you can suggest qualified people to work with, please contact me via PM.
Thanks!
Thanks!
