I'm a complete newbie and getting ready to jump in with both feet and build my first skeleton clock. I've looked at plans/books for a couple of skeletons and I have one starting question (probably with a lot more to come) and that is - Is there any reason you couldn't substitute aluminum plate for the brass plate used to make the front and back plates? If that's possible are there any modifications required (i.e. can you put a pivot or arbor directly into the aluminum plate of would you need to put in a bushing? Thanks in advance Kevin
