starlight_tools link=topic=1459.msg8072#msg8072 date=1301414158 said:
Nelson
I have a set of thin parallels and a set of the 1/4" thick ones. I also have an assortment of shop made parallels like recip saw shafts from dead tools. I am constantly using ones from all the sets, depending on what I am setting up.
The thin ones are often preferable as you can get closer to the vise jaws when you need to drill through without hitting a parallel.
Wavy parallels are on my "toget" list.
I also got a parallel spreader but can not use it as my 6" vise has jaws that are 6-1/4" wide and the seperator will only handle about 6-1/8" wide max.
Shop made stepped jaws for the vise can be very handy as well. Rick Sparber shows them in one of his write ups on his site.
Walter
Hi,
Not to try and hijack this thread. But you mention parallel spreaders, a great idea that often doesn't work real well as you've found. When I want such an item, I use rubber bands to hold parallels to the vice jaws. Or my favorite, metal pallet banding which works amazingly well. Just cut a appropriate length and bend in a vee shape. The stuff is amazingly springy and resilient. While being easily formed and cheaply gotten from the garbage can.
The import parallel sets I've used have all been pretty good tools for the price. I think all of mine have come from ENCO over the years. And plenty good for "ordinary" machining. I have 1/8", 1/4" and 1/2" sets. I mostly use the 1/2" set. The 1/8" ones just fall over on me a lot. Makes me mad when that happens. ;D So I use my rubber bands and metal pallet banding to hold them in place.
dalee
