- Dec 25, 2011
- 10,508
TLW,
I thought that I had a drawing of the direct drive pin but can't find it. But in any case, it is solid one piece. The visible end has a groove machined around it to help in pulling it out for back gear. Hidden inside the gear is a flat on one side. There is a hole drilled in the gear between two teeth that crosses the pin hole and goes on into the gear. Down in this hole is a spring with a ball nosed pin on top of it. That's all that there should be to it. When you get up to 30 posts, you will have access to downloads. You will find there in the Atlas category the owner's manual, including exploded view parts on the 3996. If you will PM me your email address, I will send you the latest version of the manual as a PDF.
