Some time ago I bought few parts for my press build. It took me a while to make the chassis. I did a quick test of the cylinder and pump on the bench when I bought it. I didn't notice any issues back then so I drained it and I put it away for 2 years.
However, this time preparing to install it in a press I put the whole system together, I did some basic testing and after I was done I left the cylinder standing on the ground with the rest of the system on a bench.
Imagine my surprise when I found a puddle of oil under the cylinder few hours later :-( I thought it is one of the fittings, but the body of the cylinder was dry(all of the fittings are on the top) and oil was only below where ram emerges from it. Clearly the leak is the ram
Now it is far too late to get any warranty. I'm pretty disappointed I didn't notice it before and I haven't tested it properly when I got it.
So, before I start ripping it apart let me ask this. Is it possible the new seals have to align under pressure and can leak a little before it is used the first time?
Also, why would a new built cylinder leak? Is it fairly easy to mess up manufacturing of those cylinders to the point of leaking with no pressure?
Finally, is there a point trying heavier weight hydraulic oil? I guess if it leaks with no pressure on it it will probably pour under pressure... If anyone has any advice please let me know.
It is the cylinder that is used in Grizzly T27978 press and other "50 ton" presses.
