New PM-1228VF-LB
StormForge
1989 VW Syncro 4WD
Sep 30, 2017
38
Hi All! I'm a new forum member and just took delivery of a new PM-1228VF-LB. Everything looks very nice so far. It was well-packed, the build quality looks great, and it fired up first time with no problems. I'm a little puzzled with the main carriage feed which has a dial marked in 16-thousandths of an inch per line with 95 lines per revolution. I'm not sure how I'm going to deal with that -- I guess I need to buy a DRO :) ?
First question for anyone who has assembled one of these: What are these two black metal channels that came with the stand? I don't see them in any of the diagrams and they don't seem to have an obvious purpose?
LitM-Yr9fK1hs69mVaeTpJVEc4ww3lTgeFTDse6HI7nDjUFqZuqnJfboIX4nVFBYXZ5Kld1bWdPHveEWBRlYXAUydy35Q6ZjdR3ORDH_UwAoIlaoXpFewDFrSxyVMwMHb_hoD6d_kVgIXG1sP-Y5lE4qeiKTSnHxRwMqBwmiLU1wd-yEbz8BXO8hbDqeU8ysS86moJic1G-uXr8Olyqckj8_YfsaJOVHzdJISKeISVWiPy_F8jYh9W5WWJ0tDZFQI12d_nxw734zf1PXhlhhXStCYR86t7XBOlpm2Md16LlLGzIMhkUkQ_Bu-MnqAqUjRc5FOO4THGf3TkwKZ_mJtqCIbfdW-rJBWyx8hmPNdvo2iIQyXpNkzsw12nSwYCtkjjdWizbKWz5M5rqMVrU6Ot_kPbCbC7X4ghbik71_BDbzQxHFC3vECAonD6XBVMxpeOR-xicJMQzeY1coI5fpZhDJq5IgjqdrEJ__qVwrbNry_f15H-NqACSTEBlsiP83EcREThkfwz6RszgVJ__NaqKMCBnnJyN4ux3iLbWhTf8CQ2vT8xCmtOK_7oLBpJ188urUT1Cf-QQ7CBW7_Qt0TIi4yKbPPqWTUweeN-7Qu8nKhORTpVlF4JzsUoMGVORRllwH_RSxJkdICGBMWMXL5gcJrihW8hx4TgA=w1400-h917-no
Thanks!
-Bill
Use a magnetic back dial indicator mounted parallel with the front bed ways, indicating carriage travel. Cheaper than a DRO... ;) The issue is likely a metric bed rack. Using carriage hand wheels is not a very accurate or easy thing anyway, in my experience, though my lathe is Chinese as well...
Thanks Bob - that's a good option. My old benchtop lathe was inferior in every way except it had a 0.001" dial which moved the carriage 0.1" per revolution -- very handy and pretty easy to get (fairly) accurate results. The hand-wheel on the 1228 moves the carriage 1.5" per revolution which worries me a bit since it seems like it may be hard to physically move the wheel in 0.001" increments. Maybe I'm worried about nothing though -- I'll do some cuts this afternoon and find out!
.1"/revolution, that would be sloooooow for re-positioning the carriage...
Thanks Frank! Although my metal channels came wrapped in bubble wrap?!? :)
B0b -- yeah, it could take a while to run the carriage to the other end -- but it was a small machine...
So, how do folks deal with carriage handwheels that move a lot for each turn? Do you just develop a knack for turning the handwheel in very small increments, or do you use the compound for lots of your X travel on small/fine parts?
That's odd! My lathe was bolted to the bottom of the box through those. I forget exactly
how it was done, but my chip pan was a little bent (really minor) and I remember that the
lathe was bolted through the chip pan and into those channels. I kept them thinking I'll use
them for something some day.
Humph, at least you got yours. I heard the container was in, but no communication if it passed QA, and if it was going to ship yet. Happy for you
