    Dismiss Notice
New Hydrashift Owner
Discussion in 'CINCINNATI LATHE & TOOL CO.' started by mukymuk, Dec 17, 2016.
  1. mukymuk
    mukymuk United States Iron Registered Member
    15
    3
    City:
    Murphy
    State:
    Texas
    -Return to Top-
    That does look sharp. I might end up doing something like that.
    I replaced the missing feet with something resembling the stock feet and got it leveled--which took a lot more time that I figured it would.
    I took the head cover off to try to find out why it make the screeching sound when I brake the spindle. Turns out the noise was coming from the small box at the top. When the brake is applied the fluid gets diverted out the black pipe and the flow is erratic like a valve is oscillating or something. It can be adjusted, so I backed it out a few turns and the sound went away and the flow was nice and steady. However, now it's having trouble shifting into some speeds. I'll get back in there and split the difference and see what it does.
    2017-02-04 08.00.06.jpg 2017-02-04 08.00.37.jpg 2017-02-04 08.21.24.jpg 2017-02-04 08.21.31.jpg
    Thanks for all the good advice guys. Helps a bunch.
    jmhoying and 4gsr like this.
  2. Plum Creek
    Plum Creek United States Active User H-M Supporter-Premium
    21
    8
    City:
    Austin
    State:
    Texas
    -Return to Top-
    Sounds like you have a good handle on it. Assuming you have the same parts manual I have, there is a pressure setting procedure in the maintenance section. All you need is a pressure gauge.
Share This Page
