- Jun 12, 2014
- 4,839
Interesting about the different pots and problems. Agree, sounds more like belt/pulley noise and possibly bearings. Looks like it has a variable speed pulley set-up. I would run the motor at something between 30-90 Hz, no lower than 20Hz. You get more cogging, poor performance and overheating problems below this range, and above 90Hz, it starts to not sound so good. It may be possible to tweak some of the VFD parameters to get some further improvement. Probably easiest for you to post the changes you have made, or the program variables. If you need the default set of commands, PM me and I can send them to you if that makes it easier.
