4
Needle Bearing Fit Question
3
Like what you see?
10
ddickey
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Apr 21, 2016
1,005
Likes
505
#1
How are needle bearings supposed to fit?
I need to replace two. Low load and speed. It's for a table on a small surface grinder. They fit tight in the housing but the shaft is a loose fit,
Desolus
Apr 27, 2017
117
Likes
72
#2
There's quite alot of needle bearings out there, you will need to give some more information. I've seen bearings held in a housing by everything from glue to a, well come to think of I don't know what it's called... like a reverse e-clip...
Pictures if possible.
ddickey
Apr 21, 2016
1,005
Likes
505
#3
They're open cup full complement I think they're called. I've installed them. Made a new shaft as the old one was worn .003" from the OD. I did some searching and thought I read for my size 1/2" x 11/16" x 1/2" shaft diameter could be .001" larger so .501" in my case.
benmychree
John York
Jun 7, 2013
998
Likes
565
#4
The shaft should fit with very little clearance; soft shaft and needle bearings is a very poor thing to do; ideally the shaft should have a hard race on it or the shaft should be hardened.
Asm109
Active Member
Active Member
Aug 29, 2017
71
Likes
80
#5
If you are talking about drawn cup needle bearings where the outer race is a thin sheet metal shell, then....
They must be press fit into the housing because the roundness of the housing is what makes the bearing accurate.
Also the shaft needs to be hardened into the Rc 55+ range. I am going from memory but a cold rolled shaft won't last long.
ddickey
Apr 21, 2016
1,005
Likes
505
#6
Yes. That's what I've been reading.
Thanks guys.
6
5 7
