well that's my luck)
M mkeller Registered Registered Joined Feb 26, 2014 Messages 25 Mar 2, 2014 #12 starting to find a few 10 hp motors what voltage should it have
J John Hasler Active User Former Member Joined Dec 8, 2013 Messages 2,651 Mar 2, 2014 #13 mkeller said: starting to find a few 10 hp motors what voltage should it have Click to expand... Same as the motor you want to run.
M mkeller Registered Registered Joined Feb 26, 2014 Messages 25 Mar 2, 2014 #14 thanks - - - Updated - - - 230/460 sound correct?
xalky Registered Registered Joined Jun 17, 2012 Messages 2,220 Mar 2, 2014 #15 mkeller said: 230/460 sound correct? Click to expand... Yes, it can be wired for either/or. That should work fine.
R Rob G. Active User H-M Supporter Gold Member Joined Mar 21, 2013 Messages 36 Mar 4, 2014 #16 I'll be following this because I need a phase converter also. I take it the capasitors are 220vac. Also how many do you need? Rob
M mkeller Registered Registered Joined Feb 26, 2014 Messages 25 Mar 6, 2014 #17 Ok I have two motor options for making the convertor, looking for input on which motor to get. both 10 hp motor 1 3450rpm 208 volt motor 2 1750 rpm 230/460
M mkeller Registered Registered Joined Feb 26, 2014 Messages 25 Aug 4, 2015 #18 update, ended up getting in over my head on the rfc, so I bought one https://www.northamericaphaseconverters.com/shop/category/pro-line-rotary-phase-converters/ its been working wonderfull powering my vmc and my air compreessor
