Need Limit Stop M6 T-nut - any sources besides Grizzly?
British Steel
Active Member
May 12, 2011
689
Likes
513
#2
A M6 nut might not have enough meat in it, but there's nothing to stop you milling some from a piece of bar and drilling/tapping them, 5mm drill and M6 tap required if you don't have 'em, a few Local Currency Units, and you'll be set up for making more when you want 'em and any other M6 threaded additions to the mill?
Dave H. (the other one)
Charles Spencer
H-M Supporter-Premium
Aug 29, 2013
972
Likes
1,002
#3
Hey, British Steel. Totally off topic but I saw the movie "Lord of the Flies" the other day. In it the character Piggy tells how the Cambridge Town was renamed Camberley.
RJSakowski
H-M Supporter - Premium Content
Feb 1, 2015
2,758
Likes
2,824
#4
Tee nuts were one of the first projects when I got my first mill. The mill was slotted for 5/8" Tee nuts but the ones which came with the set were 9/16". I have never run across a 5/8" Tee nut tapped for 3/8-16 studs so making them was the only option. Some forty years later, I'm still using them.
It is a fairly simple part to make. An end mill, a drill and a tap are the only required tools. Measurements don't even have to be that precise. For a limit stop, aluminum would be an acceptable material.
Go ahead and make them. Aside from having a supply of nuts at hand, you will have the pride of accomplishment and a sense of empowerment when you're finished.
British Steel
Active Member
May 12, 2011
689
Likes
513
#6
Don't forget, when you've made 'em, munge the last couple of turns on the underside so you can't run the bolts through all the way and out the other side, which is the quickest way to break out the top of the T-slots leaving an ugly crater in your mill table...
British Steel
Active Member
May 12, 2011
689
Likes
513
#7
Yup, it was originally named for the Cambridge Hotel, which is still standing!
The kid who played Piggy went to Camberley Primary school, and motorbike scrambling started here too :)
kd4gij
Active Member
Feb 7, 2011
3,973
Likes
1,245
#8
I use a plug tap and stop when the tap is flush with the bottom of the T nut.
jmx66
Active Member
Active Member
Jun 14, 2017
37
Likes
34
#10
Yep, those are them. I can't bring myself to spend $10 on shipping $2 worth of parts, so instead, I spend $50 on metric taps and drill bits and will spend probably an hour making them.
So now you just learned something about me. :D
hman
Feb 17, 2013
1,530
Likes
1,045
#11
What we really learned is the you're just like the rest of us! :)
kd4gij
Active Member
Feb 7, 2011
3,973
Likes
1,245
#13
If you call Grizzly you can usually get small parts shipped much cheaper or free
