- Jun 8, 2016
- 603
Folks, what I have seems to be a fully factory Logan 2537 turret lathe with a 2 speed motor from the factory. The issue I am having is the 2 speed switch. Everything is wired up, as it was when I got it, I haven't moved any wiring on the switches. The only wires I have hooked up are in the junction box on the outside of the cabinet to go to the phase converter.
So, again, the wires on the switches havent been moved. Also, I haven't connected power to the lathe yet until I get an answer to the following problem:
The 2 speed motor switch doesn't rotate. both the forward and reverse switch and the hi low speed switch are drum switches. the hi low speed switch doesnt rotate, and it appears the contacts are not engaged. Im not sure what to do, and dont want to apply power until I know what is going on.
Any suggestions?
Any suggestions?
