Hi I have a Warner Electric Bronco II model 160 DC motor control. I am hooking it up to a 3/4 hp Baldor motor on my mill. I would like to know how to adjust the pots on the drive board. The Min, Max,Torque,IR Comp and Accel pots. Thanks..John W..JW714
Thanks Tony,Unfortunatly I have no manual,and I researched the manufacturer Warner who sold it to ..... and ..... doesn't answer my E-mail. BTW .... means I forgot who Warner sold to. That's all I got Thank You John W. JW714
Sure I'll post a pic later. That Danfoss is just an enclosure that houses a KB drive. I want to change it to the WArner. I'll post pics after I get to the shop. The KB drive probably isn't set up right either because the motor would stall very easily. JW714
Thanks everybody for your help.mnmh no wonder I didn't find the settings I only looked at the quick startup guide,my bad. I now have the info I need I can't thank you guys enough...JW714
