    Dismiss Notice
Need Help Blueprinting A Part
Discussion in 'DRAWING, LAYOUT & CAD' started by Izzy, Oct 28, 2016.
  1. Izzy
    Izzy Canada Active Member Active Member
    141
    43
    London Ontario
    City:
    London
    State:
    Ontario
    -Return to Top-
    I understand the basics of lost foam casting I was just a little weary of trying it with all the comments against it... if you reckon i did lots research and planning that I could do it right then I might give it a shot! Just got really discouraged from trying is all
  2. q20v
    q20v H-M Supporter - Premium Content H-M Supporter-Premium
    126
    33
    City:
    Ottawa
    State:
    Ontario
    -Return to Top-
    Hey izzy,
    It isn't my intention to beat a dead horse, so please don't take this that way. I only hope to expand on and hopefully clarify the casting issue.
    The reason people are suggesting that DIY casting is a bad idea for this type of part is that without strict control on all manufacturing parameters the likelihood of defects are high (ie porosity, voids, metallurgical, etc). You are correct in that the part may look and function alright, however, if any of these defects are located in areas of high stress (think about the some of the loads subjected to the knuckle) the long term reliability may be compromised. Depending on the location of the defect and stress levels, over time the part may experience a fatigue failure which is very different than failure by a single overload event (like a curb hit or crash). Or, the part may endure light - med duty driving conditions, but a high speed corner with a pothole may fail the part. In industry when there is a demand for a high criticality casting , non-destructive testing (NDT) is employed to detect these defects (surface and sub-surface) to ensure a sound casting has been produced. There are national standards that cover the types and processes of NDT for metal parts based on manufacturing process, material, shape... Yes, auto manufacturers may use aluminum for their knuckles as standard parts, however these may be forgings rather than castings, which will be superior from a metallurgical and mechanical property standpoint to the casting. And if castings are used for these parts, the quality control processes would ensure defective parts are caught before they are installed on the assembly line.
    Have you thought about starting with something that from a manufacturing standpoint is a bit easier, but is still performance/automotive related? Adjustable control arms using heim joints and steel tube? Adjustable sway bar links or maybe even a beefier sway bar? Strut mounts w/spherical bearings that allow caster/camber adjustment?
    Hope this helps,
    Barry
  3. Izzy
    141
    43
    London Ontario
    City:
    London
    State:
    Ontario
    -Return to Top-
    @q20v I appreciate the response, I deffinetly don't have the sort of equipment for NDT. The auto manufacturers are cheap though they're deffinetly cast parts they don't even so much as clean up the parting line from the 2halves of the mold... I've already done away with all my bushings and my control arms are all chromoly tubing already the point here was to adress the only thing I haven't yet and that's the weight of the oem knuckle. There are options for my car but the parts cars needed to find the parts are hard to come by so I was exploring other options. I think i may be scraping the idea until I come across a parts car with the knuckles I'm looking for.
  4. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,248
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    Do you have a mill that you are planning on making this part in? If so clamp it to the table and put an indicator in the spindle and find the position of every feature in 3 axes from a 0,0,0 reference. this is the poor mans CMM. Having a 3 axis DRO will make this much easier.
    As far as removing mold and die marks from components that are not seen when manufacturing consumer products, who would do such a thing? My mother does not care if GM left tool marks on unseen parts of her car if it gets her to the bingo game on time.
    I built racecars and components for a long time in the past, weight is important, function is more important, appearance is unimportant unless you are selling them to people that require a shiny part. If on the other hand you are trying to claw your way up in the racing game make the parts so that they are lighter, work and last, most cars have a less then 1 season lifespan in use.
    jagwinn and Izzy like this.
  5. Izzy
    141
    43
    London Ontario
    City:
    London
    State:
    Ontario
    -Return to Top-
    @Wreckwreck thats some solid info! I deffinetly want to get a 3axis DRO and I do have a mill I'm currently working on getting up and running! And i couldn't agree more with your last statement, I deffinetly over engineered the car to handle alot more than it will ever probably see! Appearance has never been a factor to me just functionality, that being said I would have liked to make this part myself but the time/cost to make this might just be cheaper and take less time to track down a parts car. Maybe someday in the future I'll build this part myself and i appreciate all the help that may one day make it possible but for now I think I'm gonna lay the idea to rest.... Atleast until I'm a little better situated and ready to give it another go!
  6. Pappabear
    Pappabear Canada Swarf Registered Member
    1
    3
    City:
    Burlington
    State:
    Ontario
    -Return to Top-
    Assuming 6061, I believe your best option is to use round bar, last time I looked it was available up to 16" diameter. I did not read all replies so apologies if I am repeating what has been said previously.
    Izzy likes this.
  7. Izzy
    141
    43
    London Ontario
    City:
    London
    State:
    Ontario
    -Return to Top-
    No, nobody has recommended round bar, I dunno if it would be any cheaper than the plate stock but I'll give it a try!
  8. Desolus
    Desolus United States H-M Supporter - Premium Content H-M Supporter-Premium
    11
    8
    City:
    fort worth
    State:
    Texas
    -Return to Top-
    If needed, I don't mind sitting down with you, video chat for instance, and drawing the part in fusion 360. At first glance there's not a terrible ammount of complex geometry here.
    I agree that everything should reference the center bore.
Share This Page
