Thanks for the video.
One time, a few years ago, I looked at the original design Grizzly cat-head chuck and didn't like it because it had those hungry looking clothing grabbing bolts spinning right next to where my left hand would have to be when I was holding the chambering reamer. I regarded that as an unacceptable design, so I made my own spider chuck with recessed spider bolts. I machined it to mount on my 4J chuck back plate. The change over is fast and easy: remove 4 bolts, remove the chuck body, set the spider chuck body in place, insert shorter bolts, done.
The chuck back plate looked like this:
This shows two views of the completed spider chuck bolted in place on the back plate (prior to adding brass tips to the spider bolts), first with the spider bolts backed out to flush which would clear a 2" barrel blank, second with them in far enough to touch:
This shows the spider chuck plate in work chucked in the 4J it will share the back plate with:
That said, the spindle on my lathe is short enough that I've never had to do a rifle barrel that required the use of the cat head chuck. I actually find it easier to use the 4J with a piece of #6 or #10 copper wire around the barrel in the chuck, like this:
I originally made an add-on cat head for the back of the spindle that looked like this:
The inside shoulder:
Fits over the spindle:
Like this:
This shows the parts:
And finished:
I got tired of putting it on and off the lathe, used the 4 set screw marks on the spindle as a guide and simply cross drilled and tapped the tail end of the spindle itself:
Fitch
