Its pretty big. Not sure what to compare it too. Pacific Fu1600. Got over excited when i purchased
Looks like we both did the same thing.
I excitedly purchased a Kearney Trekker 210CH (like a 3C, i think) which looks just like an older big-brother of yours. With it, I got a 23 inch(!) KT rotary table. The rotary is wider than the mill table, but the interface is the same.
According to KT literature, the rotary table weighs 750lb. I believe it. Now while that sounds like a lot, according to the same literature, the machine weighs so-close-as-not-to-matter 10,000 lbs. So it all works.
In answer to your question, no, I don't think you can have a table too big. If the spindle can reach the center point without interference, then it's a good fit. There's no need for the crossfeed to reach beyond the center, at least not geometrically, so once again, bigger is better -- whether it is or not <LOL>
Pro Tip: Without reservation, I'd say the most important aspect is being able to remove and replace the table at-will with minimal effort. I've used a forklift, but am now installing a hoist and chain hardware. Having a big rotary table is very desirable and too cool, but being able to NOT have the table is sometimes better.
Wrat
