    Dismiss Notice
My new Taiwanese lathe
Discussion in 'ASIAN LATHES & MILLS' started by Skierdude, Sep 10, 2017.
  1. Skierdude
    Skierdude New Zealand Swarf Registered Member
    4
    3
    City:
    Auckland
    State:
    Outside US / Canada
    -Return to Top-
    So I'm new to machining. I've cut, bashed, bent and welded metal for quite some years now. Purely for fun to give me a diversion from the pain of being part of the IT industry. I've been looking to add a lathe to the workshop for a few years now. I've been looking for a good second hand machine for a while now but here in New Zealand there hasn't been a lot available that's in good enough condition. I've watched YouTube videos, read website blogs and wandered through dozens of forums gathering information to make that first purchase. I hate buying any tool only to find it isn't quite up to the job. So after much reading and with a little bit of apprehension I purchased a new Taiwanese 12x36 2hp lathe - a Hafco AL-960B.
    I have read horror stories about Asian lathes having casting sand in the gearbox, out of tolerance components and other assorted nasties so this lathe got a thorough going over as it was uncrated. I have been very pleased with what I've found so far. Castings are pretty good and certainly better than some Chinese lathes I've seen. Once the lathe was mounted on its stand and given an initial alignment I ran the DTI over most of the moving parts and it was well inside the tolerances for this unit so I was quite happy. There's a few annoyances such as the Drive belts are very difficult to change as the motor won't move as far as it should as it runs up to the rear splash guard and into one of the headstock adjustment screws. Second and more important issue is that the motor control is a simple FWD / OFF/ REV switch. Turn the power on while the switch is in FWD or REV and the spindle starts to turn. I've already bought some contractors and will be building a new electrics system. I'm learning how to grind tools and chips have started to fly so let the fun begin.
    One question, if anyone is still reading, do people use the chuck guards that seem to be supplied with new lathes. I don't see what real purpose they serve covering just the chuck and I'm not usually standing in front of the chuck. I don't recall any videos where a chuck guard is in use.
  2. Chipper5783
    Chipper5783 Active User H-M Supporter-Premium
    364
    63
    City:
    Red Deer
    State:
    Alberta
    -Return to Top-
    I use my chuck guard about 20% of the time. The wat it is set up, it just flips up out of the way. I don't have a splash guard, and most of the flying chips are launched bu the chuck - I like the guard because it reduces how many and how far the chips fly. It also reduces the spray of various oils & lubes. I do not think of it as a safety device, it simply contains stuff that would fly around more. Even if I had a splash guard (on the project list) I would still keep the church guard.
    I see you have a splash guard. Try out the chuck guard for a while - you may find you like it.
    I agree, don't stand in the line of fire off the chuck.
    BGHansen likes this.
  3. mikey
    mikey Active User H-M Supporter-Premium
    2,570
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    Welcome to HM! That's a nice looking lathe. Most guys don't seem to like the chuck guard but some do. It has more to do with preventing the lathe from running if you forget your chuck key in the chuck. It also reduces the vertical stripe of oil you get on your shirt and face when you first run a freshly oiled chuck. I don't really care for them but mine is still in place; it doesn't really get in my way ... much.
    darkzero likes this.
  4. kvt
    kvt Active User Active Member
    665
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    Like mikey said, they will prevent the oil sling on the shirt from fresh oiled chuck. I got those, as my old lathe did not have sucha thing. Have never used one but my though is how do you keep it clean so you can see through it. Scratch city. Welcome to the site and have fun.
    mikey likes this.
  5. Chipper5783
    364
    63
    City:
    Red Deer
    State:
    Alberta
    -Return to Top-
    I don't try to see through mine. I might clean it once a year. The way I have the guard adjusted, I can see just fine. Like I said in my earlier post, I don't use it all the time - it just flips up out of the way. I don't think of this as a safety item, the purpose is to reduce the spray off (shirt, wall, ceiling).
    mikey likes this.
  6. mikey
    2,570
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    It's good to know that I'm not the only one with an oil-striped T-shirt!
    Ulma Doctor likes this.
  7. kvt
    665
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    Yea, I have two lathes back to back, The front side of the back splash on one is acrylic and wipes down. The problem is the back side which the other lathe sits is not, It has a nice strip of oil from the chuck. Of course I got it from both. I even though I was standing to the side when I started it up after oiling, but still got it. I also figured out a put to much and lowered the amount I put in.
    One lathe I saw with it would not start or run with the shield up, Thus I did not like it.
    mikey likes this.
  8. richl
    richl United States Active User Active Member
    219
    63
    City:
    atlantic highlands
    State:
    New Jersey
    -Return to Top-
    Chuck guards are strictly optional, I prefer them, though not the factory model. If you find you prefer something between you and the spinning metal in front of you ... well you might consider something like this
    http://www.hobby-machinist.com/threads/flexbar-lathe-chuck-shield.61384/
    Nice looking lathe, hope you get the little niggles all sorted out.
    Rich
  9. markba633csi
    markba633csi United States Active Member Active Member
    405
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Chuck guards are good for cutting certain metals like brass which emit a spray of pernicious little chips; I had a brass chip bounce off my eyeball once
    and wished I had had a guard.
    Mark S.
  10. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,040
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    the stripped t-shirt is badge of honor for me :)
    darkzero and mikey like this.
  11. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,537
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Striped t-shirt & wall means you're doing it right! ;)
    No striped shirt for me though, I was taught to never stand in the line of fire of the chuck.
    I'm one of those who don't care for chuck guards/shields. My lathe came with one stock, it was connected to a safety switch. So if the guard was not down, spindle won't power on. Like mentioned it also prevents me from running the lathe with a key in the chuck as the guard can't come down far enough to disengage the safety switch.
    I used it for like 8 months or so & thought nothing of it. Mine blocked a lot of the oil flung from a chuck but it was not wide enough to shield from chips. Then when I started making multiples of things, as I would doing an op on each part then change to the next op, I got really tired of the chuck guard as I was swapping each piece in for each op to save time on tool changes & setup. All the chuck guard did was slow me down. Taking mine off was one of the best things I did to my lathe as it saved me so much time when do a run of parts. It served me no real benefit to keep it on so off it stays & has been for years.
    I've seen a number of guys here use the flexbar shields which look very nice, pretty expensive too. Having it not connected to a safety switch will allow you to only use it when needed & still run the lathe. Still I prefer not to have one.
    You can always try one & see if it's suitable for you. Do you have one for your lathe, it looks like the mounting arm is there.
    Ulma Doctor and mikey like this.
Share This Page
