    Dismiss Notice
My G0704 CNC Conversion - Down to the Short Rows
Discussion in 'CNC IN THE HOME SHOP' started by angelfj1, Jun 28, 2017.
  1. angelfj1
    angelfj1 Iceland Active User Active Member
    8
    18
    City:
    Downingtown
    State:
    Pennsylvania
    -Return to Top-
    Lately I'm making significant progress.
    This conversion is a Hoss-type.
    X, Y & Z Axis Ball Screws/Nuts, Mounts and Steppers in place.
    Oiling mods completed and plumbing in place.
    Mach3 installed.
    X, Y Steppers Jogged successfully but motor tuning not completed.
    Z Stepper doesn't move.
    Major Electrical Components
    X, Y Steppers - KL23H2100-50-4B, 4-wire
    Z Stepper - KL34H295-43-8A. 8-wire - connected in bi-polar series mode.
    All three Drivers - KL-5056
    BOB - C10
    X, Y, Z Driver DIP Settings
    1-off
    2-on
    3-on
    4-off
    5-off
    6-off
    7-on
    8-on
    Again, X&Y steppers jog.
    Z does not jog - it doesn't move at all.
    I have wire checked and connections are correct.
    So, I would appreciate some guidance trouble-shooting the Z motor circuit and motor winding connections and driver settings.
    Thanks in advance.
    Frank
  2. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,785
    113
    City:
    Sandy
    State:
    Oregon
    -Return to Top-
    Mach3 settings correct?
  3. jumps4
    jumps4 Global Moderator Staff Member Active Member
    181
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    Hi Frank
    I would first
    look on the mach3 main screen and make sure "Z inhibit" is not checked.
    Steve
  4. angelfj1
    8
    18
    City:
    Downingtown
    State:
    Pennsylvania
    -Return to Top-
    Thank you Jim, but if I knew the answer to that question, I'd be up and running!
    So, what do you suggest.
  5. angelfj1
    8
    18
    City:
    Downingtown
    State:
    Pennsylvania
    -Return to Top-
    Thanks Steve! I'll check that.
    Could you comment concerning the Z-Axis stepper winding connections? For Bi-polar, what would be best, series or parallel?
    In my limited experience, the Z-stepper seems to do the least amount of movement, so what would be best, highest torque or highest velocity?
    Frank
  6. angelfj1
    8
    18
    City:
    Downingtown
    State:
    Pennsylvania
    -Return to Top-
    Gentlemen, I went back and did a little research. It seems that my DIP SW setting for the KL-5056D drivers is good. So, I started trouble shooting my connections and tried a different set of connections for the drivers where they terminate on the BOB. That fixed the non-responsive Z stepper issue, and its now zipping up and down the column just as happy as could be! In fact all three axes are moving very smoothly. I really don't think the different pins I selected for X, Y, and Z made a difference - they should all work. I probably had a loose connection.
    So, now on to the next steps.
    Re-mount the head.
    Add the limit/homing switches
    Connect the oiler and check it's function
    Thanks for your support.
    Frank
    JimDawson likes this.
Share This Page
