- Feb 2, 2014
- 1,055
I have about 4 acres of grass to mow each week during the summer rainy time so when the tractor decided to stop moving it was a problem. I have a 1951 Allis Chalmers WD and a belly mower that I have used for over 20 years. Cuts over 8 feet at a pass.
Pulled it up on the cement to see what was wrong.
This is what I found. The hand clutch collar decided to disintegrate and leave the area.
And it is supposed to go here.
No parts are available new and a used search didn't bring up anything either. Because of the way it's made the tractor has to be split apart even if I could have found one to replace it. I did not want to do that and only have a week to get this working again. I don't have a piece of brass to make one out of but I did have a piece of steel plate. I figured if the brass one lasted for 65 years then one made of steel should last as long as I am around.
Put it in the 4 jaw and bored the center to size then I used a 3/16 HSS bit to bore out the inside slot. The bit was sharpened square on the end and worked like a cutoff blade in reverse.
This was the result.
My part does not include the round ears that ride in the shift fork. I plan on drilling and taping holes in these locations so I can screw in bolts for pivots. This modification should allow me to install the new part without splitting the tractor.
More later thanks for looking.
Ray
Ray
