- Aug 15, 2013
- 2,109
A new LMS 3540 8.5x20 lathe is enroute to yours truly as I type. Due for delivery next Tuesday. My soon to be former 7x14 mini lathe now sits on a Home Depot mobile workbench like the one pictured. I would like to use it as the base for my new lathe.
Due to my space limitations, it has worked great for my 7x14. Roll it out of its cubby hole to use the lathe, tuck it back in the corner out of the way when finished. The workbench is quite sturdy. It has a 575 lb. weight rating overall, though the casters are rated for even more weight. The new lathe weighs 220 lbs with chuck and tailstock. I have about 50 lbs of tools, accessories and valuable junk stored in the drawers, mostly concentrated on the end away from the headstock. The bench top is 1/2" thick hardwood, 46" wide x 18" deep x 37" high. I will bolt the new lathe to it. What do you LMS 8.5x20, 8.5x16 or Sieg SC4 owners think? Will it work? Thanks.
Tom
Tom
