Mounting holes
Bushranger
Jun 4, 2020
6
OK, probably a strange question, but I'm making adjuster feet for the Hercu 9 AR. The plan is to have the feet bolted onto the cabinet then onto the bed supports with an aluminium plate to spread the load a bit. My question is, are the hole distances the same on the headstock end as the tailstock? Also, does anybody happen to know the actual distance? I'd like to have everything ready to bolt on when I lift the lathe.
The bolt holes appear to be 6" apart, from front to rear, and 31 1/4" from headstock to tailstock. The headstock bolts are 8 1/2" from the outside of the gear cover. The front bolts are parallel to the front of the bench (no offsets).
