    Dismiss Notice
Mitutoyo post style backplate for dial indicator
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by petertha, Jan 13, 2017.
  1. petertha
    petertha Canada H-M Supporter - Premium Content H-M Supporter-Premium
    165
    43
    City:
    Calgary
    State:
    Outside US / Canada
    -Return to Top-
    Just wondering what would be the application for this back plate style? Its a cylindrical post 12.7mm diameter (0.5") either with or without presence of a threaded hole in the end (M6x1 or 1/4-28 UNF).
    I could see if the post was 0.375" diameter like the stem, you could maybe grip the indicator in a different way in a magnetic holder, but what does the 1/2" OD hook up to?
  2. talvare
    talvare United States Ted A H-M Supporter-Premium
    320
    63
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Could possibly be used in a chuck or collet for sweeping inside of a shallow bore ?
    Ted
  3. Matthew Gregory
    Matthew Gregory United States Active User Active Member
    18
    8
    City:
    Glenwood
    State:
    New York
    -Return to Top-
    I just bought a couple of these to convert some lug-back dial indicators to .375". You have to turn them down - they're considered 'in-the-white', and are oversize to accommodate someone needing a different diameter, for whatever reason. Would be nice, however, for them to offer a standard .375" post for this application, though. Being cheap aluminum, there was quite a bit of porosity apparent as I cut them down...
    francist likes this.
  4. francist
    francist Canada Active User H-M Supporter-Premium
    582
    93
    City:
    Victoria
    State:
    British Columbia
    -Return to Top-
    That would explain why the Mitutoyo catalogue shows them as "custom". I'm thinking, how can you have a 'custom' part in a catalogue -- that doesn't make sense. But an oversize one to produce a custom one does. Thanks for that explanation.
    -frank
  5. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,096
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    I've seen inspection fixtures where the post sat down in a c'bore and held in place with a 1/4-28 socket head cap screw from the back side.
  6. kd4gij
    kd4gij United States Active User Active Member
    1,070
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    They are good for the noga bases also.
  7. petertha
    165
    43
    City:
    Calgary
    State:
    Outside US / Canada
    -Return to Top-
    My Noga holder is max 0.375" hence the question. Does your Noga have a 0.5"" hole?
  8. kd4gij
    1,070
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    I don't have a noga I have a clone. You just turn the pin down to size. My self I just make the backs I want. for a quick just cut a lug off sand flat and put a 3/8 post with a 10-32 screw.
    4gsr likes this.
Share This Page
